Old 01-05-2011, 04:11 PM
hawk1 is on a distinguished road
torq cut 22 problem
I bought a 1997 torq cut 22 about 3 months ago. Ever since I got it has had this same problem... only now its worse.
When I turn the power on in the back usually I get to the c prompt and type RUN and it boots up fine, sometimes it won't boot it just goes back to the flashing c prompt again. If I turn the power off it usually works the 2nd or 3rd time.
But, sometimes when I turn the main power on all I get on the screen is RGB no input signal. again if I shut it down a couple times it usually works... not today. I have spent all day trying to get it to boot and nothing.... I have checked fuses, breakers...and fiddled with alot of plugs and still nothing. I even tried earlier rebooting the start up disc, (sometimes that works) but still nothing, and now I can't even get the screen to boot past this RGB no input signal.
Any ideas ???
Old 01-06-2011, 07:50 AM
Moderator
machintek is on a distinguished road
It is possible you have a bad logic power supply, a bad motherboard, or a bad video board.
does it at least seek the floppy for a few seconds during the boot time? If so the mother board is at least functioning. Then take out the video board (if so equipped), clean the edge connector with a soft eraser and put it back in.
If not get a meter and check that at a 4 pi plug coming out of the logic power supply you have 5VDC between red and black and 12VDC between yellow and black.
George
Old 01-07-2011, 04:11 PM
EFI-Unlimited is on a distinguished road
Mine does the same thing sometimes when I fidgit with the RAM sims or the video card. Usually, if I go and wiggle or press around either of those items, I can get it to boot again.
Brian
Old 01-08-2011, 08:15 AM
tpmx57 is on a distinguished road
I have had this problem at times also.
I end up cleaning things and usually get it to run.
Sometimes I believe that turning power on and off several times getting it to boot is what took out my BMDC board.
Just a thought but it was after my machine sat a month it didnt want to boot up and I tryed about four times powering on and off and thats when my
BMDC went out,maybe a coincidence but I have wondered about it.
TORQ-Cut-22 tpmx57 Bridgeport and Hardinge Mills 3 07-21-2010 08:28 PM
Need Help!- Torq cut 22 Dirtman Bridgeport and Hardinge Mills 0 06-02-2010 06:53 PM
Need help! Torq cut 22 TLO.. Freewheels Bridgeport and Hardinge Mills 1 12-14-2009 11:00 PM
Need Help!- Torq Cut 22 Tool Changer Problem MetalicGlow Bridgeport and Hardinge Mills 8 12-08-2009 07:41 PM
Need Help!- DNC to TOrq Cut 22 Drexelracing Bridgeport and Hardinge Mills 6 01-16-2009 04:51 PM
