Old 01-05-2011, 08:22 AM
Dezmond is on a distinguished road
Newbie Help Please with Motor Conversion
Hey Everyone!!!
I have the chance to buy a older model Bridgeport mill for a GREAT price. Problem is that the motor on it is rated at 3 phase 575 volt.
I have a little shop that only has 220 volt single phase in it.
I got quotes on re-winding the motor to 220 3ph and a VFD but MAN it costs more than the price of the mill.
Can I just make a new mounting plate and just mount a 110 or 220 volt motor on there? say a 2 or 3hp? Since the speed is variable by clutches in this model I would have to worrie about speed control correct? It has the dial on the front...
Any help would be great.. I hope to get this up and running soon to get back into the great machining hobby again.
Thanks Everyone...
Old 01-05-2011, 08:34 AM
M250cnc's Avatar
M250cnc is on a distinguished road
To change the motor you would also have to change all the control gear on the mill
The cheapest option is a rotary phase converter i use one in my shop i can run up to three machines at a time
Phil
Old 01-05-2011, 08:50 AM
Where did you get your phase converter? Are these expensive?
Old 01-05-2011, 08:51 AM
mactec54 is on a distinguished road
Dezmond
Is this just a manual mill, if it is try Ebay for a 220V Bridgeport motor,You has a variable speed drive,So you will have to get the Bridgeport motor, It has a special shaft on it for the variable speed pulleys
For VFD drives Ebay again,Will get you the best deal, Try the Drive Warehouse
Mactec54
Also why would I have to change gear controls etc? I though this motor was attached to a pulley and belt. I figured we could mill the pullry to the new shaft and key and bushing if needed...
Just trying to figure this out to the cheapest method
Old 01-05-2011, 09:19 AM
Dezmond
You only have to change the motor if it is a manual mill, The shaft on the motor is about
6" long, You would have a hard job to put a standard motor on it, the shaft on the motor is also hardened
The photo will give you a better idea
Mactec54
Old 01-05-2011, 09:24 AM
Hmmmmm. Why not weld to the shaft and turn it tru again on a lthe and then all set. Should I go to a bigger motor as well? say 3hp
Old 01-05-2011, 09:36 AM
M250cnc's Avatar
Control Gear as in the electronics or at least rewiring as they will be the wrong voltage.
Phil
Sent from my HTC Desire using Tapatalk
Newbie - Proxxon BFW 40 CNC conversion Trevix Benchtop Machines 17 11-19-2009 08:27 AM
Possible Servo Motor Conversion? ahooper Servo Motors and Drives 0 07-23-2009 01:33 AM
motor conversion reedmiles Bridgeport and Hardinge Mills 0 09-13-2007 05:29 PM
Newbie Looking for Advice (Sherline or HF Conversion) Deviant Benchtop Machines 21 09-26-2004 08:10 PM
CNC conversion on a Harbor Freight 44142 3 in 1? Newbie seeking help. David Bord Benchtop Machines 3 08-22-2004 08:06 AM
