Old 12-31-2010, 10:21 PM
mark562 is on a distinguished road
Angry Brigdeport Interact 1 Mk2 24v Regulator
Hello All
Had an alarm DC VOLTAGE MISSING today, After 3 hours of searching I finally found the 24 volt regulator split in half. I temporally bypassed the regulator with a jumper wire and the machine runs fine.
I went to radio shack & bought a 7812 regulator and soldered in place. It Still Refused to work, I used a plastic rod to poke at the solder joints to make sure they were connected. When I bumped the wire leading to the first resistor on the board, The new regulator exploded (So much for the poking around method)
Any one have the spec's on this Board, it doesn't look that complicated but I don't know the difference between the 4 resisters on this board.
I can solder fairly well, but must face the fact that I'm a machinist not an electrician.
Mark
Old 01-01-2011, 08:38 AM
gus gus is offline
gus is on a distinguished road
I am not familiar with that board, but if there are stripes on the resistor, they will tell you the value. look up the resistor color code on the web.
you can also get a meter and check the value
Old 01-01-2011, 10:03 AM
awemawson is on a distinguished road
12 or 24v?
Originally Posted by mark562 View Post
Hello All
Mark
The 7812 is a 12v regulator not a 24v. Presumably if you bypassed the original regulator you are running on the unregulated voltage that's maybe 30-35v - could cause you a few problems in the future if components downstream are not rated for the higher voltage.
Andrew Mawson
East Sussex, UK
Old 01-01-2011, 03:05 PM
Yes Andrew the power supply is putting out 30 to 35 volts. I only bypassed the regulator to test the machine. (not running this way). The Radio Shack package was marked "7812A 24v Regulator" if this not right then maybe thats why it blew. The original was damaged to badly to get numbers off of so tried the first 24v I found, Can you recommend one that will work?
Mark
Old 01-02-2011, 01:50 PM
7812 / 7824
Well it should be a 7824 as a generic part number. You need to check what current is drawn as those regulators tend to come as 100ma or 1a versions.I wouldnt personally run with the original regulator linked out, as it will do damage.
Andrew Mawson
East Sussex, UK
Old 01-02-2011, 03:55 PM
john_100's Avatar
john_100 is on a distinguished road
Hi Mark
just a thought
the maximun input voltage for 78xx series 1 amp regulators upto 18v output is 35v
as the center 0v ,lead is connected to the metal tab
could you have shorted the output when you gave it a poke ?
the 24v regulator you want is ok with 26v to 40v input
does the regulator have a diode across the input and output ( 1N4002 ?)
the cathode connecting to the 30- 35v input
it provides a discharge path when you switch off for any voltage stored in a capacitor on the output
can you confirm that you need the 1 amp version
as the 78L24 = 100mA o/p
78M24 = 500mA o/p
7824 = 1 A o/p
78S24 = 2A o/p
if you only have radioshack to buy your parts from and they don't do the 7824 regulator
you may be able to use a 7812 12v regulator and a 12volt zenner diode
the cathode going to regulator 0v terminal and the anode to the pcb 0v
John
ps any chance of detailed photos of both sides of the board
Old 01-02-2011, 07:38 PM
john_100's Avatar
just an example of a 12v regulator used in a commercial 24v design
note the TIP31A transistor to pre regulate the supply to the 7812
and the 1N5349B 12v zener to provide a + 12v voltage to the 7812 ground / reference terminal
Name:	24v  1A psu.jpg‎
Need Help!- Regulator MR-S1-80-E31 MITSUBISHI MILJENKO Mazak, Mitsubishi, Mazatrol 0 11-14-2010 06:42 AM
Need Help!- Post processor Brigdeport VMC560 Mindstorm Post Processor Files 0 12-26-2009 03:36 PM
Newbie- Air Pressure Regulator? Raykomo Wood Lathes / Mills 1 04-23-2009 01:51 PM
12V regulator N4NV General Electronics Discussion 6 03-16-2007 09:28 PM
PS Regulator freezer General Electronics Discussion 8 02-13-2004 09:48 AM
