Does anyone know where I can send a Siemens ER Module out to be tested? The machine (VMC-760 corca 1993) is getting a couple of non repeating faults. Spindle drive fault comes on and then goes off, the X drive axis fault intermittently shows up also. Nothing consistant they come and go. Thanks
__________________ Still working in the "D". |
| Let me pose another question. Has anyone retrofitted a newer CNC control to an old machine? Where do I start looking for this information? Any recomendations for a company? The machine is rock solid albeit a little slow. I hate to pour a ton of money into her or worse scrap it out because the electronics are acting up. Machine; VMC-760 Year; 1993 Control Heidenhein TNC 2500B Thanks.
| I can`t help with where to send it as I am in the UK but have you asked Siemens? Is it a 6SC-611 drive that the ER unit is from? They are quite reliable unless you lose a phase while it is powered up.The early ones destroyed themselves when that happened. I think the early ones are obsolete as ISTR Siemens saying they couldn`t get one of the original components and the replacements would not stand the 11Kva flashover test they give them.Be careful if you`re messing about with it as the dc link voltage is 660 volts. For a retrofit if the machine is worth it I would use a Siemens 802. |
try doing it yourself. when you see spindle drive fault , error code should appear on the 7-segment display on the spindle drive, so open the door and check the error code number. for the x-axis drive, swap the drive with y-axis, as they are the same. then see whether the dive fault alarm occur on X or Y. |
| We had a service guy out to look at the machine. He swapped the X and Y axis and it didn't make any difference. The randomness of the faults suggests it's getting a bad signal from somewhere. He suggested maybe the ER Module, so my boss told me to pull it and send it out for testing. I ended up sending it out to ERD in North Carolina. ERD Industrial Electronic Repair 99% in-house repair - 2 YEAR WARRANTY
| Siemens 6ES7-350-24H00-0AE0 Counter module | chalky501 | EBAY ADS | 0 | 08-23-2010 01:46 PM |
| Need Help!- Is it safe to underpower my motors for the test bench? | jestah | DIY-CNC Router Table Machines | 4 | 02-21-2010 12:41 AM |
| This is a test thread in the test forum | adam.faris | Test Forum | 1 | 10-26-2008 11:21 PM |
| Diesel Test Bench | turbocanuck | General Electronics Discussion | 5 | 11-15-2006 02:44 PM |
| Please need help on I/O Module | yeager | General Electronics Discussion | 9 | 01-13-2006 08:19 AM |
