Old 12-29-2010, 12:43 PM
ichudov is on a distinguished road
What is the BACK GEAR RATIO for Bridgeport Series II Interact 2?
I need to know the exact back gear ratio for Bridgeport Series II Interact 2. I need to know it exactly, because I need it for rigid tapping.
I know that it is between 8.2 and 8.42 from just looking at my dial, but I need to know the exact value, not approximate.
The specs on my spec sheet say 8.3:1 ratio, but I am not totally sure if this is this ratio exactly or approximately (as in teeth ratio).
http://igor.chudov.com/projects/Brid...Mill/specs.jpg
Old 12-29-2010, 12:55 PM
Torsten's Avatar
Torsten is on a distinguished road
You will need an encoder on the Spindle to do rigid tapping.
The Spindle speeds given in the manual will only be aproximat anyway.
So your 8.3 : 1 should be close enough.
Old 12-29-2010, 12:58 PM
I already have an encoder, it is on the driven pulley.
So the encoder is 1:1 when I am in straight gear, and in 1:RATIO when I am in back gear.
I need to know that RATIO.
i
Old 12-29-2010, 01:02 PM
Torsten's Avatar
i
You need the encoder on the spindle, so it is allways 1:1.
else it would be useless.
Old 12-29-2010, 01:04 PM
Why is that so, if I can use a ratio to convert pulley rotation into spindle?
I already do rigid tapping in straight gear. I just need to find out the back gear ratio and I can then also tap in back gear.
Need Help!- bridgeport series 2 interact 4 dcchip Bridgeport and Hardinge Mills 3 11-15-2010 04:47 PM
Need Help!- bridgeport series 2 interact 4 dcchip Bridgeport and Hardinge Mills 5 04-30-2010 07:27 PM
Need Help!- bridgeport interact 4 series 2 gideon233 Bridgeport and Hardinge Mills 3 02-15-2009 08:05 PM
Need Help!- Bridgeport Series 1 interact tnc 145 jaztau Bridgeport and Hardinge Mills 2 10-20-2008 04:12 AM
Need Help!- Bridgeport Series 1 Interact zorba99 Bridgeport and Hardinge Mills 7 06-11-2008 07:59 AM
