Old 12-24-2010, 08:08 PM
jroberts1968 is on a distinguished road
Bridgeport J125528
I found this local for 1600.00. Any advise would be great.
I just do not know enough about used Mills to make a educated decision and do not want to throw 2500 more in it to make it work.
I am looking at PM30 or PM45 but my shop can fit a BP in it.
BRIDGEPORT MILL- J125528 - US ELEC MOTOR 123024 - SPINDEL SPEED 80/135/210/225 OVER 660/2115/1750/2720 - 1 HORSE POWER - 3 PHS - CYCLE - 50- VOLTS 208/220/380/440 - AMPS 4.6/4.4/2.5/2.2 RPM 1420 - 1730
Old 12-25-2010, 06:06 PM
jmelson is on a distinguished road
It is a manual machine. The 1J head has 4 speeds adjustable by belt setting and a backgear drive for 4 more speeds, as you show. Probably has the R-8 spindle taper. 1 Hp motor, 3 phase.
But, that's just the specs. Condition is everything. Ways can be worn, Acme screws can be in bad shape. If you want to convert to CNC, then starting with a machine already set up for CNC is a much better choice. If you want a manual machine, then that doesn't matter.
Jon
Old 12-25-2010, 08:24 PM
cheetahcnc's Avatar
cheetahcnc is on a distinguished road
The fixed speed belt heads are less expensive to get going, that is a plus. Every used Bridgeport (or similar) I've purchased, needed the variable pulley system repaired. Inspect the collet seating surfaces of the spindle, then chuck a length of precision round, about 3/4", and put an indicator on it and give it a spin manually. I have found machines with very little brake left were used a little harder. The price is in the range I see in many machinery auctions.
Jim
Old 12-27-2010, 10:07 PM
Moderator
machintek is on a distinguished road
This must be quite old. It has the 36 inch table. That has to be considered too.
George
Old 12-28-2010, 07:39 AM
Smrtman5 is on a distinguished road
I spent about $500 rebuilding my bridgeport. New gibs, x & y nuts, and a couple of missing handles and dials and some paint. I didnt dare take the head apart (1J), but it ran well, so i was lucky there.
I finished it off with about $500 in startup tooling: vise, endmills, indicator, etc. Certainly worth the investment for me. I later added a DRO.
Bridgeport TC3 HRL General Metalwork Discussion 0 04-11-2009 04:29 PM
Bridgeport INT 412 Jurek Want To Buy...Need help! 0 04-06-2009 10:35 PM
bridgeport cnc toolclaw General Metal Working Machines 3 12-16-2008 10:23 PM
Bridgeport CNC tpmx57 Automation Technology Products 1 09-06-2008 11:12 AM
Used Bridgeport - What to look for? smird Bridgeport and Hardinge Mills 11 04-17-2005 10:45 AM
