I have a 1995 EZ Trac SX and the control system will not start up. Are there parts out there for this system or better yet is there a way to up grade the computer to a current day system with out spending the price of a new machine. any one that sells an up grade kit for this mchine? |
| There is alot of parts to be had for these machines pretty cheap. what is your machine saying on the screen? I have 2 EZ-TRAK's personally i like the features and won't upgrade. There is enough people on here to help you fix it pretty easy |
| when you turn on the power the display says "NO Signal" in the center of the screen for a few seconds and then is blank. the CR 1 relay goes in and out once at the same time the red lights on the large computer circuit board blink on and off once. |
| I could be wrong but sounds like the computer power supply is shutting down. check the cooling fan on it and make sure it is turning and verify the +12v and +5v dc power is there on one of the spare drive connectors. i had a power supply in one of mine act like that. if it's not that i would suspect mother board issues. let me know what you find and i will try to help if i can. |
A new one from Amazon will run in the neighborhood of $35 or so. |
| We experienced a similar problem on our machine. We contacted EMI inc.(601-287-4240). They sell an updated motherboard to replace the old 486 board. Our cmos battery died and corroded the motherboard. The new board is around $800, but it eliminates the video board and add-on drive controller board. Our board should arrive in a few days, I'll let you know how easy(or hard) the upgrade is. If it is the power supply, I took one out of an old pc in the basement and it worked just fine going on 7 years now. |
taking into account I have replaced motherboards in PC's before: The board got here at 10:30 this morning, its 12:44 and the machine is up and running. Thats with a half hour lunch in between. Everything plugged right in and lined right up, no muss no fuss. |
| Ez trac sx wiring | 999le | Bridgeport and Hardinge Mills | 4 | 06-12-2008 12:59 AM |
| Bridgeport EZ-Trac post processor | got_woody | Post Processor Files | 2 | 02-11-2007 03:24 PM |
| ez trac voltage issue? | plkelly | Bridgeport and Hardinge Mills | 4 | 05-16-2006 05:05 PM |
| How to repeat a EZ-Trac Program | Stoney372 | Bridgeport and Hardinge Mills | 4 | 02-16-2006 01:24 PM |
| ez-trac problems | Dan D | Bridgeport and Hardinge Mills | 8 | 06-26-2005 07:09 PM |
