Old 12-17-2010, 04:58 PM
lloydsp is on a distinguished road
DNC protocol for BOSS9 R2E4
I have fully restored a Series I R2E4 to original electronics.
I have a need to use the "drip feed" method (DNC protocol) to work large programs.
I cannot find any documentation on the protocol. It's not just a matter of the correct COM port settings. I can communicate with the machine just fine, but I can never get the "DNC off" flag to turn to "ON", and I overflow the DNC buffer every time I try to send even one short block in the "load DNC" mode. (It's not flow-control, either, unless I'm missing something really basic).
Does anyone have documentation on the protocol? I can do the coding to build a software to do the work, but I need to know what to write.
Thanks,
LLoyd
Old 12-17-2010, 07:48 PM
Moderator
machintek is on a distinguished road
EZLINK software by Bridgeport through port B only at 4800 baud. 8 data bits, 2 stop bits, no parity, X on X off enabled.
George
Old 12-17-2010, 09:36 PM
got a copy that will run on something other than COM1?
EZLink isn't a protocol, it's a program that executes a communications protocol.
The rest isn't protocol, either -- it's configuration. Baud rate, parity, start/stop bits, all that I have right already. I can upload programs smaller than the 12 buffer limit successfully.
That's why I'd love to know what - exactly - the Bridgeport DNC protocol IS...
LLoyd
Old 12-18-2010, 02:03 PM
DNC figured out.
I have the DNC protocol, now. As time permits, I'll document it for you.
It's both as complex OR as simple as you'd like to make it. Bridgeport guys figured out some nice "hacks" to make it work with just about anything.
LLoyd
Old 04-19-2011, 04:22 PM
zam10 is on a distinguished road
I have the ezlink software but it is always warning that can open Com1 port , how can I define Com 2 port ?
Alejandro
Old 04-19-2011, 06:33 PM
Alejandro
You cannot do that in EZlink, but you can re-define the port assignments in the Windows system hardware definitions (control panel, system). It's no big deal, easy to do.
LLoyd
Old 04-21-2011, 08:10 AM
Thanks , I´ve already changed at Windows the Com port and know EZ link works ¡
LLoyd
Hi , thanks, It is now working changing the Com port asignated by windows , to Com1
Boss9 R2E4 series 1 Parts jeep534 Bridgeport and Hardinge Mills 0 02-27-2008 12:31 AM
R2E4 Boss9 Problems JohnJames Bridgeport and Hardinge Mills 4 10-25-2007 12:03 AM
Drip feed Boss9 pcsimp Bridgeport and Hardinge Mills 5 08-12-2006 07:38 AM
Can't talk to my Bridgeport R2E4 (Boss9) Tom Long Bridgeport and Hardinge Mills 7 06-27-2005 09:31 AM
Programmers Manual BOSS9 pcsimp Bridgeport and Hardinge Mills 2 03-24-2005 10:47 AM
