Old 12-15-2010, 07:43 PM
mally is on a distinguished road
Heidenhain TNC145 Programming
Hi Guys
Just trying to get my head around MDI-ing a LBL into a prog, I have written a contour, but now I want to repeat and incrementaly put a cut on in Z till I have reached total depth I know it's easy but Help!!!
Old 12-16-2010, 07:08 AM
gus gus is offline
gus is on a distinguished road
LBL 1
IZ-.05
[contour]
LBL 0
CALL LBL 1 REP 5
remember you can only call a label with multiple reps once, so you may have to make a work around. If you try it will blow right through the LBL 0, so it is wise to put the labels at the end and put a stop below them. Get in the habit of putting all Z moves outside of the label, allowing you to change all sorts of things when needed.
Old 12-24-2010, 07:18 PM
Thanks Gus for the help
Cheers
Merry Christmas and prosperous new year
Need Help!- setting up heidenhain tnc145 kolb13 Bridgeport and Hardinge Mills 6 08-13-2010 06:35 AM
bridgeport 2/heidenhain tnc145 Dar Bridgeport and Hardinge Mills 4 03-19-2007 08:05 PM
bridgeport 2/heidenhain tnc145 Dar Bridgeport and Hardinge Mills 1 03-12-2007 03:24 PM
Need Heidenhain Tnc145 Post For Pro/e Wildfire ARIF AHMED Post Processor Files 0 10-16-2006 10:48 PM
Heidenhain TNC145 post zafarsalam Post Processors for MC 2 04-09-2006 08:26 PM
