Results 1 to 5 of 5
Thread: Bridgeport DX-32 Program (Please Correct)
    Feb 2009
    I would like to circle mill a chamfer on a Outside Diameter. The following program does not start the spindle or go to Z .1 in the proper sequence. Please correct the program as needed. Your help is greatly appreciated.
    Regards,
    Bob
    G90 M6
    T1 S1000 M3
    GO X-4.0 Y4.0
    G175 X0.0 Y0.0 Z.1 R.5 Z.2 Z.2 P0.0 P0.0 F15.0 F15.0 F15.0
    G0 X-4.0 Y4.0 T1 M6
    M2
    Jun 2010
    TRY THIS
    Try this
    G70 G90
    T1M06
    S1000 M03
    G0 X-4.0 Y4.0
    G175 X0.Y0.Z.1 R.5 Z.2 Z.2 P0.0 P0.0 F15.F15.F15.
    G00 X.40 Y4.0
    M02
    Feb 2009
    Allan:
    Many Thanks for taking the time to correct my program. I can't wait to try it.
    Best Wishes!
    Bob
    Feb 2009
    Allan:
    I could not get your corrected program to work.
    After many attempts the following program worked. Does this format look familiar.
    G70 G90
    G0 X-4.0 Y4.0 T1 M6
    S1000 M3
    G0 X0.0 Y0.0
    G175 X0.0 Y0.0 Z.1 R.3125 Z.2 Z.2 P0.0 P0.0 F15.0 F15.0 F2.0
    T1 M6
    G0 X-4.0 Y0.0
    M2
    Thanks Again and Best Wishes!
    Bob
    Mar 2008
    Quote Originally Posted by minton View Post
    Allan:
    G70 G90
    G0 X-4.0 Y4.0 T1 M6
    S1000 M3
    G0 X0.0 Y0.0
    T1 M6
    G0 X-4.0 Y0.0
    M2
    Bob
    Not sure which machine you have but if the X-4.0 Y4.0 is a spot that you change your tools at, you might want to try the “clear point” feature.
    From the setup – jog menu position your table wherever you would like and set the clear point there. Then try this program:
    G70 G90
    G0 T1 M26
    S1000 M3
    X0.0 Y0.0
    G0 M22
    1. Bridgeport lathe problem,is this the correct forum?
      By hdjeffrey in forum Bridgeport and Hardinge Mills
      Last Post: 01-14-2009, 03:22 AM
    2. program handling software bridgeport
      By windy in forum Bridgeport and Hardinge Mills
      Last Post: 10-31-2008, 06:45 PM
    3. Need Help!- Bridgeport Boss 9 Program Storage
      By drjimmy in forum Bridgeport and Hardinge Mills
      Last Post: 02-20-2008, 06:24 AM
    4. Bridgeport CNC New Program Error
      By Monk in forum Bridgeport and Hardinge Mills
      Last Post: 08-17-2005, 12:32 AM
    5. How do you make Bridgeport execute program?
      By Bill Gillen in forum Bridgeport and Hardinge Mills
      Last Post: 06-14-2005, 09:26 AM
