Old 07-06-2005, 11:07 PM
jerid1 is on a distinguished road
bridgeport mill series1 boss 4?
I have a bridgeport mill series1 boss 4? and are trying to retrofit a stepper cnc pacage from cam soft but are having problems. It kinda moves when I try to move it, it moves one step or .0001. Does the bridgeport mill series1 boss 4? use step and direction in stepper cards that are driving the origenal stepers I am trying to spend the least amount$
anny help will be great
Thanks jerid1
Old 07-06-2005, 11:35 PM
unterhaus is on a distinguished road
I believe they use a different system. It still works with a parallel port, but I think it's phase drive. I can't imagine that mach2 doesn't support it. I know that EMC does support it.
Old 07-06-2005, 11:57 PM
someone said that the bridgeport mill series1 boss 4 dose notwork with step and direction
Old 07-07-2005, 07:50 AM
Moderator
machintek is on a distinguished road
FYI: As a function of the amount of poles, ball screw pitch, and pulley ratios, the BOSS 3, 4, and 5 step in .001 inch steps. The BOSS 6 steps in .0005 inch steps.
George
Old 07-07-2005, 02:06 PM
As I said before, the Bridgeport uses phase drive. From what I understand, this means you are sending the pattern for bipolar half-step drive out the parallel port for each axis. I would think there are other options, but EMC is the only one that has it supported for sure. If you go to http://linuxcnc.org you can find out more about EMC. The user's handbook can be downloaded from http://sherline.com/emc/User_Handbook.pdf
I checked in the Mach handbook and only saw a discussion of step/dir interface. There is no reason why it couldn't use phase drive, but I guess Art hasn't felt that there was a need.
Old 07-07-2005, 06:10 PM
I found out what kind of signal bridgeports put out, it can be incremental /decremental input not step direction
Help w/Bridgeport series1 textron CNC MrHorsepower Bridgeport and Hardinge Mills 28 02-10-2010 01:49 AM
Gecko in Bridgeport BOSS zcases Gecko Drives 30 11-21-2009 10:47 PM
YA Bridgeport BOSS capability zcases Yeager Automation 1 10-18-2006 10:48 AM
Bridgeport Boss Retrofit help moto21 Bridgeport and Hardinge Mills 7 06-09-2005 10:32 PM
Bridgeport R2E3 with Boss 8 John Bennett Bridgeport and Hardinge Mills 5 04-06-2005 10:06 AM
