I like to convert my Bridgeport ez trak dx 2 axis (1995)to a 3 axis machine, Is it posible to build in an extra servo amplifier like in the electrical diagram and buildt a quill drive with the same servo motor(sem TM30-H4-44) as the x and y axis . which servo amplifiers can i use is it posoble to set it up with the same software i run now version 3.04. any help is welcome. |
| You could wire in the extra servo amp and motor to get the 3rd axis. the hard part is interfacing the motor to the quill. my 3 axis EZ-TRAK uses the cantilever design which is basically a gear box and a linear actuator hooked to the 3 bolt holes in the bottom of the quill. you could take the light bar off z and use an encoder for more accuracy. But better yet you can get a cnc head for this machine for $2500 then u just need motor and encoder and the servo amp. this setup would be alot more accurate. there is a design that hooks off the piece that the light bar hooks onto the quill. But i haven't found a kit for that yet. I'm not real sure but from my understanding of the system you could use just about any motor and servo amp that accepts a 0-10volt torque mode input and has a quadrature encoder output. but i haven't tried that yet. I have 2 of these beasts. One is a 2 axis the other a 3 axis. I do know the bmdc3 card is recomended for the 3 axis machines. |
| Need Help!- EZ TRAK OFF IN Z AXIS | dmac88 | Bridgeport and Hardinge Mills | 3 | 07-08-2009 12:22 PM |
| New Machine Build- post for 2 axis ez trak versus 3 axis ez vision | tooolman | G-Code Programing | 0 | 11-28-2008 03:33 PM |
| 4th Axis for EZ Trak | Grayling | Bridgeport and Hardinge Mills | 2 | 09-01-2008 01:05 PM |
| EZ-Trak Z Axis Trouble | ivangene | Bridgeport and Hardinge Mills | 2 | 01-24-2008 12:40 PM |
| EZ-Trak losing Y axis Zero | melamark | Bridgeport and Hardinge Mills | 4 | 08-30-2006 10:52 AM |
