Results 1 to 7 of 7
Thread: Use of TTL rotary encoder instead of 11uA heidenhain
    Nov 2006
    pakistan
    Members,
    Is it possible to use TTL square wave rotary encoder with 500PPR instead of current interface 11uA with same PPR (both have A,A bar,B,B bar,C,C bar ) into TNC 407.
    Dec 2003
    The 11µA uses a totally different interface so I cannot see it being possible.
    Nov 2006
    pakistan
    Thanks AL_THE_MAN
    I have another question
    On a TNC 407, I have an spare encoder for X-axis siemens ac servo motor. It is not installed to the motor,
    1. I want to connect it with the control unit.
    2. By rotating it i want to see change in postition display of X just to confirm that it is in working position.
    Is it possible
    Dec 2003
    If it is the same type encoder you should be able to, the controller may give you a following error after so many counts.
    Oct 2008
    Malaysia
    Quote Originally Posted by wahidbashir View Post
    Members,
    it is possible only if you have the converter/adapter as well.
    Nov 2006
    pakistan
    Dear kongzai,
    Do you know some links from where to get adapter?
    Oct 2008
    Malaysia
    Dear kongzai,
    i have no idea of what brand of encoder you are using.
    just for your reference, i replaced a Heidenhain linear scale with a set of Fagor's + the adapter, for a much cheaper price.
    adapter i used is for 1Vpp to 11uA conversion.
    http://www.fagorautomation.com.br/no...TER_SA_P_C.pdf
    1. HEIDENHAIN ROD 271 ENCODER
      By CHANDRU in forum Bridgeport and Hardinge Mills
      Last Post: 05-30-2010, 07:45 AM
    2. Heidenhain encoder
      By N4NV in forum Servo Drives
      Last Post: 06-17-2009, 09:36 AM
    3. Problem- Heidenhain Encoder
      By Rupe in forum General Metal Working Machines
      Last Post: 12-09-2008, 04:04 AM
    4. Heidenhain encoder help
      By dave3431 in forum General Electronics Discussion
      Last Post: 10-06-2008, 05:45 PM
    5. Heidenhain encoder
      By N4NV in forum Gecko Drives
      Last Post: 02-10-2007, 11:24 AM
