Hi all, I'm new to this forum so please go easy on me! I'm going to have a look at a 1992 Bridgeport VMC1000/20 on Monday and have a few questions about the control Heidenhain TNC 2500: 1. I would like to connect this machine via RS232 to a computer so I can feed programs from Mastercam X3. Where would I find the serial port on the machine if it has one? 2. Does Mastercam X3 (full version) have a post processor for the TNC 2500 control? Also where can I find a guide on how to set the machine control up to talk to my pc? 3. Are there any common faults with this control and the Bridgeport VMC I should be aware of and look out for? I've also attached some pics of the machine, to jog the memory! Thanks in advance, Paul |
| First, go to the heidenhain website and download manuals. IIRC the 2500 is really a TNC360 It does have an rs232, but the newer ones it is right on the front. dunno where yours is, search for the 25 pin connector Heidenhain is pretty fussy on comm issues, search this forum for comments the control does ISO g code, and the are posts around |
| Ah memories... Can be a bit leaky and jam up in Y-axis if it isn't cleaned out regular. From pics it looks like tool change button is missing a bulb and cover. This could well be the actual machine I used to run... if it is there will be a circular cut about .1 deep in the table![]() DP |
| Thanks everyone, I will bear all your comments it in mind when I view it tomorrow. The dealer told me that the parameters for the spindle motor encoder will be reset tomorrow morning before I view. Would I be right in thinking that this could be due to the battery back-up failing? |
![]() ![]() you will see a battery low alarm on the screen after you switch on the machine, if you do have a dead back up battery |
| Great machines, easy to use an old computer running the Heidenhain DNCserver to drip to machine, ethernet from your MC machine to the server. You can also upload and download the machines parameters using the same connection, I am not down for more then 5 mins if I loose all parameters. The encoders on the X,Y,Z drive motors are very hard to get, $2500 per & 8 week lead time. We are attempting a retrofit with a $300 encoder. Looks beautiful! |
| Gear Hobbing using Vertical Machining centre | gajjarcnc | General Metal Working Machines | 1 | 10-26-2010 10:25 AM |
| Need Help!- Bridgport VMC760/20 w heidenhain Tnc2500 | rmarchjr | Bridgeport and Hardinge Mills | 2 | 12-01-2009 08:49 AM |
| Need Help!- Heidenhain TNC2500 or TNC360 post | santosa | Post Processors for MC | 1 | 06-18-2009 03:14 PM |
| Chevalier Vertical Grinding Centre | ben_heinman | Fanuc | 0 | 03-31-2007 08:25 AM |
| Basic questions about Bridgeport VMC1000 with Heidenhain control | Roe Racing | Bridgeport and Hardinge Mills | 9 | 03-02-2006 04:54 PM |
