Old 11-15-2010, 05:10 PM
tstom is on a distinguished road
760-22 x axis problem
I have a 760-22 that has a tight x axis Probably a year maybe more ago Machinetek had posted about shimming the plates that go under the ways I did this and the machine ran great until a month ago I found the oil line to the ball screw broken and replaced it The mill ran good for about 2 weeks but the ballscrew is tight again I have also cleaned and regreased the thrust bearings on each end of the screw They looked to be in good condition
The ball screw looks smooth and shiney I guess I'm to the end of my knowledge which isn't all that far Any help would be appreciated
Old 11-15-2010, 07:11 PM
Moderator
machintek is on a distinguished road
Back to square one. You do not know what the issue is so loosen the screws on the X axis keeper plates a turn and see if it frees up. Go from there.
George
Old 11-16-2010, 10:05 AM
Loosened the front keeper plate and tried to turn the ballscrew by hand it turned snug for a bit then freed up so I tried to retighten the plate and the screw got a little tighter but nothing like before I loosened the plate I can still turn it by hand
I cut a strip of .001" shim stock ,loosened the plate and inserted the strip between the way and the turcite plate on the left end it pulls out with slight resistance on the right end it will pull out but has a lot of resistance so I guess I have slightly less than .001" clearence I'm confused as to how the screw can free up so easily after it was so tight and then is still be free when I tighten the plate back up
Tom
Old 11-18-2010, 06:38 PM
cncserveng is on a distinguished road
your ballscrew could be damaged, it is not good practice to shim things unless you have measures the clearances. With a good axis it should be possible, without the motor, to turn the ballscrew freely by hand.
Good suggestion to put things back as they were originally and go from there.
Old 12-08-2010, 06:37 PM
rmarchjr is on a distinguished road
on all my 760's we can turn x & y by hand with motors off. i think your ball screw may be damaged, if its very shiny its prob worn.
I've heard they don't do well without way oil for very long.
Z Axis Problem - please help topduck Taig Mills & Lathes 20 03-16-2010 10:35 PM
.001 Z Axis Problem BlueFin Tormach PCNC 18 12-07-2008 08:41 PM
Need Help!- axis problem bbrown2005 Mach Mill 16 09-08-2008 06:43 PM
Need Help!- ref axis problem destro Machines running Mach Software 1 06-28-2008 11:25 AM
Problem with Z axis MagTDK DIY-CNC Router Table Machines 56 10-31-2006 08:12 PM
