Old 11-14-2010, 08:45 AM
dws_engineering is on a distinguished road
Bridgeport 560/22 swarf conveyor coollant pump not working? Help needed :)
Turned on m/c this morning and the coolant overflow warning came up on the screen, turns out the motor isn't kicking in when the float is raised.
The motor works as flicked the contactor over on the switch and works as should. but won't do it when the float is raised.
It seems like there is a timer on the float switch that tell the n/c that the float switch has been up for too long. and flashes up 'swarf conveyor coolant overflow'
Is there a fuse or a relay gone somewhere? was working fine yesterday.
any help would be great as got so much work to do on it.
many thanks
David
Old 11-14-2010, 12:48 PM
The float switch relay is working as it should. so really unsure as to what the problem is
Old 11-18-2010, 06:28 AM
does anyone know what parameters that controll of the swarf conveyor and the float switches are?
Need Help!- Anybody have a working PCI parallel card for G540 w/ charge pump enabled? Jr's Farm Gecko Drives 27 04-16-2011 01:23 PM
Homebrew swarf air blower & coolant pump guru_florida Benchtop Machines 34 05-28-2010 01:20 PM
What M code for swarf conveyor? cossiegaz Fanuc 1 06-03-2009 06:46 PM
Problem- message - swarf conveyor not started - michael88 Fanuc 2 11-25-2008 07:02 PM
Need Help!- Bridgeport Interact 412 CNC pump needed TalonGrip General Metal Working Machines 0 09-03-2008 05:53 PM
