Old 11-12-2010, 08:27 AM
RMARCH's Avatar
RMARCH is on a distinguished road
Bridgeport interact 412 tool changer problem
When My tool changer goes towards the Spindle to change the tool it does not slow down before it reaches the tool like it use to. The tool changer dampens when it goes back but not towards the tool.
Any ideas ?
Thanks !!!
Ray
Old 11-12-2010, 08:00 PM
Moderator
machintek is on a distinguished road
If memory serves me correctly,your tool changer is moved forward and backward by way of a air cylinder. These typically have built in bumper at the end of stroke. The main port gets closed off by the piston leaving a smaller passage for the remainder of the travel. Usually these smaller ports have a adjustment for fine tuning that last bit of travel velocity. Maybe your adjustment has backed out or you have a issue with the cylinder.
George
Old 11-16-2010, 03:49 PM
RMARCH's Avatar
George
Hi George, You have a good memory !!! Plus you are so right !! Shortly after i posted this i remembered i had this same problem years ago, then it hit me............the small adjusting screw at the end of the cylinder.
Thanks so much !!
Old 11-26-2010, 09:32 PM
mytms is on a distinguished road
help with progran transfer
Hello
Not trying to jack the thread, but I'm new to this forum. I need to transfer my programs and am at a loss. I have a interact 412 with tnc351/355 control. If someone could give me some help or direct me to someone who could I would appreciate it very much. Right now I'm trying to download to mastercam and am getting a framing error on my computer. I tried to download the tncremo but cant get it to run. Once again any help would be very appreciated
Duane
Old 12-04-2010, 03:51 PM
windy is on a distinguished road
thanks for the heads up,my 412 thumps the stop at tool change, nowI know why, just have towork out where this adjuster screw is then
Old 05-06-2011, 11:18 AM
mikemtz123 is on a distinguished road
HELP ME!!!!!
hello. i have a bridgeport vmc 560 with 16 tools, i was having a problem with the machine but we can fixed, but we cant fix a problem with the tool changer.
if some body could help me please!!!
Bridgeport Interact 412 Tool Changer Problem RMARCH Bridgeport and Hardinge Mills 17 05-09-2011 10:57 AM
Interact 412 - Tool Changer Not Back noremac Bridgeport and Hardinge Mills 0 06-14-2010 04:15 PM
Bridgeport series II interact II tool holders ? bigtoad170 Bridgeport and Hardinge Mills 18 02-26-2010 10:14 AM
Need Help!- How do I adjust the tool changer height parameter on a TNC145 (Interact 412) Skin Bridgeport and Hardinge Mills 3 05-27-2009 07:16 PM
Bridgeport Interact 24v DC reg problem Paul_Leoni Bridgeport and Hardinge Mills 3 11-14-2006 03:15 AM
