Old 11-07-2010, 08:01 AM
CanAmUWHGear is on a distinguished road
Transistor Troubles?
After scouring the forums about information as to why my BP series one has issues with the y axis and z axis, I have come to a few conclusions....
1. I have issues with the transistors
2. I cannot find any information as to how to test/verify the transistors on these boards.
Can someone help me with a procedure to test the transistors to see which ones are bad/faulty? Pictures and explanation will help me very much. I do have a good multimeter and can use it. Here's what I have...
BP series one with boss 5, converted to hillybilly board and mach 3 control.
X axis works great, Y axis makes noise but doesn't turn much, just wiggles back and forth and Z axis is dead.
THanks for your help!
Steveo
Old 11-07-2010, 10:29 AM
Johann ohnesorg is on a distinguished road
WTH is a hillbilly board? Show us a pic! Concerning transistors, they are the last things that will fail on a board.
Check your connectors, resolder every solder joint and check for blown/leaky caps.
Old 11-08-2010, 06:49 AM
Moderator
machintek is on a distinguished road
Usually the 2N6547 will short between the emitter and collector (the two big wires). I put my meter on diode check to see the voltage drop across the semi-conductor junction. The odd ball one of the four is probably the one that is bad (zero voltage drop as it is shorted). Do not know anything about a converted machine but check the fuses if an axis is not doing anything. I am assuming Z is at least free to move mechanically.
George
Old 11-08-2010, 06:58 PM
tpmx57 is on a distinguished road
I run one of Derecks(Hillbilly) boards on a Series II with Mach III and blow a transistor once in awhile but usually just if I have to hit the E-stop.
Check them like George says then replace and keep going
Old 11-09-2010, 11:46 AM
Frustrated...
Fuses looked good, transistors looked good...so I bought some stepper drives from machmotion.com. If anyone wants, I have all of the old cards/drive stuff for sale...cheap..send me a PM if your interested.
Steveo
Newbie- transistor as switch methuso General Electronics Discussion 8 09-03-2010 01:01 AM
Transistor Blew Again!! ranchak Bridgeport and Hardinge Mills 9 01-06-2010 09:20 PM
transistor substitution keebler303 General Electronics Discussion 4 08-25-2006 10:20 AM
Transistor Question DANIEL HALL General Electronics Discussion 17 01-07-2006 12:16 PM
transistor question scott m General Electronics Discussion 9 07-22-2005 06:38 AM
