Bridgeport Explorer, DX-32 Control When the machine is shut down, restarted, homed, then positioned at the previous X 0.0, Y 0.0 the X axis does not repeat. It is usually off by a -.100 I think this is called grid jump. How can this problem be resolved? As always, Many Thanks for the Help! Regards, Bob Adams 989 798 6581 |
| Is it off by exactly .100? I would look in your service manual, under x-axis motor replament. In there, you will find a spec for when the x-axis home switch should 'make'. Go to the maint prog, and verify this contact closure is within spec. Brian |
happens on my r2c3, I think it is as mentioned above, when the encoder ref mark is too close to the trip dog, it can miss it[IE one time it hits the trip dog before the ref mark, the next time after] resulting in an exactly .100 error |
When the dog hits the home switch the motor rolls back to find the pulse marker. Depending on how close it is to the marker the motor may back off 1 full rev. Try moving the dog one way or the other around 1/16th of an inch and see what happens. |
| Z Axis home position problem Arrow 500 | BSavulis | Cincinnati CNC | 23 | 03-09-2011 09:39 AM |
| Change position of A axis home | mishikwest | Haas Mills | 3 | 07-23-2010 02:52 AM |
| Bridgeport Explorer X-26 \ DX-32 Won't Home | XxLT250RxX | Bridgeport and Hardinge Mills | 2 | 04-23-2010 07:16 AM |
| Need Help!- Z axis home position reset | Paul in OK | Haas Mills | 9 | 05-13-2009 08:05 PM |
| Z Axis Home Position Problems | JMFabrications | General Metal Working Machines | 3 | 10-24-2006 10:58 PM |
