I am about to undertake this project and I was curious how everybody else goes about mounting the servos and how big of pulleys they used. Did you have to make a new bracket or is it just as easy to modify the ones that are there already? I was told to get pulleys and belts for a 3:1 ratio when I bought the controller and servos. I wondered if anyone might possibly sell some sort of a belt and pulley kit that is ready made for this? I am completly lost as to what size pulleys and belts to get. I would appreciate any suggestions. Thanks... John |
Hey! Thanks very much for the reply.... I bought the controller as a package deal from CNC - MachMotion.com. They refer to it as the "TECO" kit. My origional plan was to retro a small Rong Fu benchtop stepper machine that I have been playing around with until I was able to save up enough $ to get a bridgeport. Guess I should make it clear that I have never tried anything like this before. It is something I have wanted to do my whole life but never had the guts to try. Anyway, I got this control home and I quickly began to realize that as much work as it takes to do this, I only want to do it once so I waited until I had a BP to do it on. Another member here sold me a beautiful series 1 with a BOSS 3 controller that still works save one small glitch that we think is just a transistor. It seems a shame to remove it from the machine but the new control is here to stay and it MUST GO.I guess I should try to resell. IDUNNO. Since my last post here I did manage to find a very very helpful build log titled "Amae's Bridgeport Series I BOSS3 retrofit" that gave me some really good ideas for the pulleys. That entire log is really worth a look for anyone who is new to this. So,,,,,, I am contemplating going with a 24 and a 72 tooth pulley. As this guy's build log suggested, I found a website that provides a 3D cad drawing of all of their pulleys, and I intend to make them myself from that cad file. The idea being that I will cut several of them out of quarter inch material and pin them together to make a single 1 inch wide pulley. I would have never in a million years come up with an idea that brilliant. So that is my game plan and I would very much appreciate ANY ideas or suggestions you might have. Again, thanks for your reply. John..... |
| Hey John checked out your teco ,wish I bought that set up . 24 and 72 is a better set up, but I am happy what it can do it has never stalled i cut out shapes in 3/8 thick Alum in one shot , 56 tooth was under 6 inch in dia .making your own gears is great if you have the time , for $84.00 you can buy one. Here is the timing gear I used .McMaster-Carr |
| When I tought about the time I would spend and all the asses I would have to kiss to make my own pulleys, it was rather clear that you have the better idea. I looked at the link you sent me and I was unable to find the 20 tooth pulley that you spoke of. I was curious if perhaps you might have been mistaken on that and actually got the 22 instead? The reason I ask is not to be a smartass, I am more concerned with getting the right parts and doing this right. I am really flying blind on this deal and would appreciate any advice you might have. I assume that 8MM is the pitch. Is this correct? I really don't know how big or small of a pitch one could vary on this and still have enough grip to not wear the belt out or something. Like I said, any advice is greatly appreciated. Also, I was curious why you did not retro the "Z" on your project? It would be cool to see a pic of this beast you created B.T.W.~~~~ Thanks very much for replying. John.... |
| jcox1968 What size are the Teco motors you are using,(How many Watts) The normal Boss up to Boss 5 run a 1.1 ratio, with your ballscrews you already are at 5.1 ratio,I used the standard pulleys, on the machines that I have built
__________________ Mactec54 |
Continuous running duty Rated output (W) 750 Rated torque 30 in/lb Class (21.16 in/lb) (2.391 Newton meters) (338.6 oz/lb) Maximum torque 63.4 in/lb (7.164 Newton meters) (1014 oz/lb) Rated speed (r/min) 3000 Rated current (A) 3.4 Encoder 2500 line Hopefully this is the info that you asked for. Thanks, John |
| jcox1968 The 750watt motors you have, will run your Bridgeport Boss 3 at 1.1 ratio, so you can use the original timing pulleys, you may need different bushings, in your pulleys to suit the new motors,But they are easy to find & bore to the size you need, put the keys in them as well, or they will slip on the shaft without them
It's frustrating doing this, here is a place where you can get the 20 pitch gear, you may have to find a distributor in your area . sprockets, gears, sheaves, bushings, couplings, idlers, drag conveyors, screw conveyors, bucket elevators, industrial hand tools, forgings. |
| Bridgeport Series 1 CNC retro | RickDLance | Want To Buy...Need help! | 0 | 02-14-2010 01:12 PM |
| Project Retro/rebuild Bridgeport Series IIA (2) NC | JimPAC | Bridgeport and Hardinge Mills | 34 | 05-31-2007 06:49 PM |
| Bridge port series II NC 1973 Retro help | astro02 | Bridgeport and Hardinge Mills | 20 | 01-04-2007 11:30 AM |
| series 1 cnc retro? | sdeering | Bridgeport and Hardinge Mills | 3 | 09-05-2006 10:29 PM |
| New guy with a Bridgeport series 2 retro. | rrefx | Bridgeport and Hardinge Mills | 2 | 12-27-2005 01:21 PM |
