Old 10-21-2010, 07:31 PM
loose1 is on a distinguished road
bridgeport boss steppers and mach 3
Does anyone have a good stepping off point for the drive settings on stock steppers running mach3 on a BP boss 5?
Thanks Matt
Old 10-22-2010, 06:49 AM
jthornton is on a distinguished road
You might have better luck with a mack question over in their forum but I would never use a Windoz based controller for a CNC machine even if it was free... way too much going on inside of Windoz to have a reliable real time system.
Just my 2 cents.
John
Old 10-23-2010, 08:57 PM
HawkJET's Avatar
HawkJET is on a distinguished road
Originally Posted by loose1 View Post
Does anyone have a good stepping off point for the drive settings on stock steppers running mach3 on a BP boss 5?t
Matt, what drivers are you using and what voltage?
I have a Boss 3 with stock steppers. I have Compumotor drivers and am running them at 6 amps.
Or is your question about speed and acceleration in Mach?
If so, I'm at 110 ipm and 4 in/sec/sec.
This is a conclusion based PURELY on superstition. There are tens of thousands of machines doing this quite well (if not more). Yes, windose has its quirks, but many can be eliminated (as Art has with Mach 3) and the rest can be minimized. The result is that Mach 3 is a very nice CNC controller... correction... Mach 3 is an amazing CNC controller (especially when considering its bang for the buck)!
"Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take away." Antoine de Saint-Exupery (1900 - 1944)
Old 10-24-2010, 05:47 AM
No, it is not based on superstition, I have tried Mack and found that it could not perform up to what I needed to run my plasma table. For me the best "bang for the buck" is free open source software that runs in a linux real time environment. Software that runs properly on mills, lathes, gantry machines, plasma cutters, hexapods... well anything with up to 9 coordinated joints of motion. And yes Art has done wonders porting it to windoz with some amazing tricks.
John
Old 10-24-2010, 09:47 AM
HawkJET's Avatar
This has absolutely NOTHING to do with the operating system and EVERYTHING to do with what the software was intended for.
Mach 3 and EMC2 are designed to accomplish two different objectives. They are fundamentally different at their very core. It is NOT due to the OS.
I have found numerous examples where EMC2 cannot fulfill my needs.
EMC2 is also an amazing program with great bang for the buck. I will probably use it at some point in the future. At present, it doesn't fulfill my needs and Mach 3 does. Neither program is a panacea and to automatically put down one or the other because of the OS is closed minded. Linux is not without its own issues either.
Old 10-24-2010, 06:00 PM
I'm running gecko's for drives. I got it running intell my pc that I just bought took a crap.
Matt
Need Help!- New NEMA 42 steppers for BOSS mills CNCISME Bridgeport and Hardinge Mills 3 07-30-2010 12:56 AM
Need Help!- Having trouble with steppers on Boss 6 novice5 Bridgeport and Hardinge Mills 1 12-18-2009 08:47 AM
Need Help!- BOSS I, DeskCNC, steppers don't work rpgdeity Bridgeport and Hardinge Mills 5 07-16-2009 03:38 PM
Archie's first cnc machine Bridgeport R2E4 Boss 9 to Mach 3 jeep534 Vertical Mill, Lathe Project Log 8 09-10-2008 12:47 PM
Bridgeport BOSS steppers with Gecko? damae Bridgeport and Hardinge Mills 10 10-09-2005 05:28 PM
