Old 06-21-2005, 10:58 AM
zukes3140 is on a distinguished road
CMOS Question
Would you please explain the term CMOS that come up on my EZ-TRAK Screen? Thanks Zukes3140
Old 06-21-2005, 11:05 AM
Al_The_Man's Avatar
There are two definitions of CMOS, one refers to IC technology, but in your case on a computer or PC it usually refers to the CMOS housekeeping that is stored in memory such as system configuration and date/time etc, this message usually means the battery has died and the CMOS memory is lost.
Old 06-21-2005, 10:34 PM
Moderator
machintek is on a distinguished road
Correct. It usually means the mother board may not know the time, date, type of floppy drive, hards drive parameters, etc. These may need to be put in each time you power up the machine or the battery needs to be replaced. If a Ni-Cad battery is left there, it may leak its guts out and eat away the deposited wires causing a permanent failure.
George
PIC Embedded design Question musicmkr PIC Programing / Design 24 07-23-2010 10:29 PM
Extremely basic machining question. touser General Metalwork Discussion 9 06-19-2005 12:51 AM
Question about power supplies dowling177 General Electronics Discussion 1 01-28-2005 07:01 AM
Hobbycnc controler question chas Hobbycnc (Products) 3 09-09-2004 05:00 PM
Just a question about plunge milling. Machine1 Hard and High Speed Machining 4 01-28-2004 08:36 PM
