Old 06-19-2005, 09:20 PM
MrHorsepower is on a distinguished road
Help w/Bridgeport series1 textron CNC
I am considering the purchase of a Bridgeport Series 1 with a textron cnc controll. I can't seem to find much about it anywhere. Is anyone familiar with this? Will it do 3 axis? The people that I would be buying it from said they had it hooked to a PC based "cadkey" system but couldn't tell me about as the guy who ran it has left the co. I own bobcad 18 and use it frequently, will i be able to get the code to this machine? Does this setup lend itself to a new controll like from ah-ha or flashcut, etc. I would like to add a forth axis table some day. Any help would be great.-Dave
Old 06-19-2005, 10:02 PM
Karl_T's Avatar
Karl_T is on a distinguished road
You've got a good candidate machine for a PC retrofit control. IMHO, Mach2 or Mach3 is your best bet for the control. There's a good how to series in Home Shop Machinist magazine for just this machine. And lots of folks on this NG can help out. You need to do a bunch of reading, first.
As to fourth axis, no problem. But I'd tackle that after you've got the rest of the machine up and running.
Karl
Old 06-20-2005, 05:08 PM
Thanks for the info. Do you know anything about the Textron Controll that is on the machine? The machine is in good working order and I would like to use it before I tackle the retrofit.-Dave
Old 06-20-2005, 05:17 PM
Karl_T's Avatar
I programmed one a few times. No electrical expertise at all. They have a reputation as a total POS for repairs. IMHO, use till it breaks. Don't spend $.02 on repair when it does go.(Well, I might replace a fuse - once) Repalce it with Mach2/3.
I really like the series 1 mechanically. I like the versitility of a knee mill and its rigid for its size.
Karl
Old 06-20-2005, 08:42 PM
Will I just need the software and cables or will it need new "drivers". where can i get more info on Mach2/3
Old 06-20-2005, 08:48 PM
braidmeister's Avatar
braidmeister is an unknown quantity at this point
My recommendation would be to 'flushy flushy' the factory electronics and replace with Larken or Gecko stepper drives, breakout board and mach3 front end.
BobCAD will getcha going...but you may find it limiting in the future unless you are strictly doing hobby work.
-Brady
Old 07-18-2005, 08:59 AM
digga_b is on a distinguished road
Hello all, just found this site and have already learned quite a bit! I am planning on picking up my first mill this saturday and it happens to be what title of this thread is about (BP series 1 Textron). I'm sure I will have a few questions later on. Thanks!
Old 07-18-2005, 10:13 PM
Good to know I'm not the only Nubie out there.-Dave
Old 07-19-2005, 01:50 AM
We all have to be newb's sometime!
Old 07-19-2005, 09:08 AM
A little more info on mine, just paid for it and picked up all the manuals. Operating manual, Programming manual, Maintenance manual, and 2 parts manuals. It is a Series 1 V2E3 Boss 8. Comes with 2 spare spindles, 2 extra servo motors, 2 new belts, EZfile system. All this for $500, did I get a deal or what?
Old 07-19-2005, 04:18 PM
Moderator
machintek is on a distinguished road
If the LCD display works, you got a deal. If it does not, I have NO idea where to get one.
George
  #12   Ban this user!
Old 07-19-2005, 06:10 PM
The LCD display does work. At least it did the last time I saw it run, which was about a year ago. How hard would it be to retrofit a pc control, or can it be done?
Using your CNC Mill as a CNC Lathe lstool Knee Vertical Mills 10 08-02-2010 12:06 AM
Making money with CNC Johnuk CNCzone Club House 26 12-13-2009 10:46 AM
Beginners CNC Advice UKRobotics General Metal Working Machines 5 10-08-2009 11:10 AM
CNC deviation error Alex S.A General Electronics Discussion 6 10-22-2004 02:10 PM
The start of a big CNC project... UKRobotics General Metal Working Machines 10 09-30-2004 05:34 PM
