Old 09-28-2010, 03:00 PM
*Registered User*
EIUNJ is on a distinguished road
Graduate Student help Solidcam -> CNC
I am graduate student at Eastern Illinois University, for my thesis work I am using our CNC (Bridgeport VMC480P3) and solidcam 2010. We have the post processor information from Solidcam but are not able to make the connection between the laptop and the CNC to send the g code. Any help or direction would be of great help to my thesis work. Thanks in advance!
Old 09-28-2010, 04:44 PM
D-Money is on a distinguished road
What kind of connections does your CNC Controller have? Serial? Parallel? USB? Does it have a 3.5" floppy drive or a PCMCIA Card Slot? Does it have 802.11 wireless, or 802.3 ethernet?
Are you planning to run small programs which can fit onto a floppy, or medium size programs (bigger than floppy capacity but small enough to be fully loaded into the CNC memory), or huge programs that need a tethered PC to use DNC mode?
Old 09-28-2010, 07:30 PM
jalessi's Avatar
jalessi is on a distinguished road
http://www.compumachine.com/Support/...anual_2006.pdf
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 09-29-2010, 01:27 PM
*Registered User*
I believe we are trying to use a ethernet cable but there may also be a PCMCIA cable as well. As far as program size, we are starting smaller but would eventually like to have the machine hardwired together and utilize DNC.
Old 09-29-2010, 02:19 PM
If you're going to be connecting directly from the CNC to the PC, you generally can't use a standard ethernet "patch cable" as the "pinout" won't match. You'll either need 2 standard ethernet cables and an ethernet hub, or forget the added expense of a hub, and just use a "crossover cable" that has the correct "pinout" for connecting 2 computers directly to each other, without needing a hub.
PCMCIA isn't a cable, but an expansion card type for laptops (such as PCMCIA modems, network cards, wireless cards, etc.) What you'll see quite often in machine shops is "Compact Flash to PCMCIA" adaptor cards, which lets you take a standard compact flash memory card, and allow you to use it in a PCMCIA card slot.
Old 10-26-2010, 09:44 AM
*Registered User*
D money-
I think I'll be investing in the PCMCIA Card as you described...any suggestion on a card that will work with the particular Bridgeprot VMC480p3 and work on a dell M4500? Also would a pcmcia card with a usb adapter be usable as well? Thanks for the help again I appreciate it!
Nick
Old 10-26-2010, 06:07 PM
D money-
Nick
Nick,
Offhand I don't know the maximum storage limits for a Compact Flash card when used in the VMC480p3. It was suggested to consult the Programmer's Reference guide included on the CD-ROM that came with the system...Not a big help, heh.
What we did here for our non-networked machines was to use a desktop PC with a USB-based Compact Flash card reader to copy the program onto a 2 GB Compact Flash card. We then remove the CF card and place it into the PCMCIA to Compact Flash adaptor, and plug the adaptor into the PCMCIA card slot on the machine in question, usually a Makino v33 Graphite.
Old 10-28-2010, 06:00 PM
*Registered User*
Would a pcm card that uses a USB drive work the same as a compact flash card?
Old 10-29-2010, 04:07 PM
I've never seen it done, so I can't say whether it would work or not.
About to graduate from Machining School mallenby CNCzone Club House 11 11-13-2008 12:30 PM
Problem- Student highmikebart G-Code Programing 10 02-01-2008 08:54 AM
Student highmikebart G-Code Programing 4 02-01-2008 12:39 AM
Student Here FAMOUSX1 Teachers Hang out 8 04-22-2007 11:24 PM
I want to be a CNC student praetor General Metalwork Discussion 6 10-02-2005 05:11 PM
