Old 09-25-2010, 01:21 PM
Mastersmach is on a distinguished road
TC 22 Y AXIS DRIVE PROBLEM
Hello,
New to the sight and I see many helpful people are here. I have a late 90's Bridgeport Torqcut 22 with dx32 controller. When I fired it up this morning and tried to enable the drives I got an alarm. "PM Y AXIS DRIVE OVER CURRENT FAULT".
Things I have tried bases on other similar threads and manual trouble shooting
-Checked fuse on Y axis board (Not blown)
-Checked all voltages (All seem to check out)
-Swapped X and Y motors ( Same Y axis alarm)
-Axis drive boards all have green lights on
Any help would be appreciated on direction to go next or what I should be looking for.
Jeff
Old 09-25-2010, 01:33 PM
Moderator
machintek is on a distinguished road
Might be a bad axis drive board. Swap the X and Y drive board and see if the error follows. Note that the Z board is usually a higher current board since Bridgeport went to a Parvex motor to support the Z axis without a counter weight. All these motors are the DC type and have brushes. These need to be checked every 4000 hours of running per a service bulletin from Bridgeport.
George
Old 09-25-2010, 05:20 PM
Thanks George for the fast answer. I switched the drive boards and the error did follow. So I take that as it is the Y axis board. Anything I can look for on the board itself or is it time to change out the board?
Thanks again,
Jeff
FR-SE spindle drive problem kudos Mazak, Mitsubishi, Mazatrol 42 09-04-2010 08:25 PM
3 axis dual drive, drift problem!!! antonzedd Carken Products (Deskam, DeskCNC etc) 4 02-28-2010 03:45 AM
Problem with a KTK drive pjeran Bridgeport and Hardinge Mills 2 07-22-2008 12:29 PM
Simple, 3 Axes with Dual Drive/Motor (per axis), hardware splitter drive Interface. kreutz Stepper Motors and Drives 3 07-03-2008 06:57 PM
fanuc axis drive problem turbo bob Fanuc 6 10-30-2006 04:10 PM
