Old 09-24-2010, 10:21 PM
C.T. is on a distinguished road
conversational programming
I am in the market for a used cnc knee mill or bed mill. But I am concerned about the controls. I need conversational something easy to learn because I still have to make a living. I have two cnc lathes now a Bridgeport ezpath and a Harrison alpha 550. So I am not completely lost. Would a pc based machine be better?Are the later models easier to program.
Old 09-25-2010, 12:41 AM
Perseus is on a distinguished road
what´s the cnc control? because the most important in the cnc machines is the cnc control
regards
Old 09-25-2010, 01:06 AM
christinandavid's Avatar
christinandavid is on a distinguished road
I learnt on a Bridgeport Interact 4 with an ancient Heidenhain Control. 'Knee' style mill, pretty indestructible. I know, 'cause many apprentices had a go at destroying it. Found conversational mode a lot more user friendly than ISO mode. Very basic commands and pilot manual is still available online.
Newer controls are more powerful in a lot of respects, and preferred by the seasoned operator - but the navigation through the various screens along with the vast array of options can be daunting to the beginner.
DP
Old 09-25-2010, 07:44 AM
BlueChip's Avatar
BlueChip is on a distinguished road
Offline Conversational
You can free yourself from the "conversational" control by using offline, PC based conversational software .... our KipwareM is a PC based conversational software that outputs "fanuc compatible" code pout of the box. About 90% of CNC controls are "fanuc compatible" so all you need to look for is a CNC control that is "fanuc compatible" ... and you should find a lot of choices.
Info on Kipware at www.KentechInc.com
Old 09-25-2010, 11:43 AM
jthornton is on a distinguished road
I have one conversational and 3 g code cnc's and the only difference is the labels. For example RAPID = G0, LINE = G1, ARC = G2/3. Once you learn the machine it don't matter what you call it IMHO.
John
Old 09-27-2010, 08:44 AM
The Alpha I have has offline pc software write the program on my laptop and download via rs232 port.
Need Help!- Conversational programming on CNC 88HS control rifleman Fadal 4 01-23-2009 01:01 PM
Hurco conversational vs. Milltronics conversational dfpen HURCO 10 12-29-2008 03:35 PM
Need Help!- Edgecam and Mazak/Mazatrol conversational programming shape Mazak, Mitsubishi, Mazatrol 1 12-19-2008 08:57 AM
New Conversational Programming Software BlueChip Product Announcements & Manufacturer News 1 01-25-2006 01:35 PM
Conversational CNC Programming BlueChip Product Announcements & Manufacturer News 0 07-24-2004 01:37 PM
