Old 09-16-2010, 11:34 AM
mally is on a distinguished road
Interact 2 Series 2 Spindle "no start"
Turn power "ON" Push "CE", Then orange power "ON" button, Comes on ok, Turn and hold spindle direction switch and push green Spindle "Start", Spindle spins in direction for 1 or 2 revs, Then lights and power cuts out machine resets and crt msg comes up "power interupted" checked incoming phases all seem ok but machine ran on 220v and now input is 210/208 is this TOO LOW?? Could do with a wiring schematic #215-126c to try and trace relays Etc what do you think????
Old 09-17-2010, 04:16 AM
gus gus is offline
gus is on a distinguished road
you may need to change jumpers on the input transformer
Old 09-17-2010, 06:37 AM
Moderator
machintek is on a distinguished road
Is it on a phase converter?
George
Old 09-18-2010, 06:18 AM
Hi
No it is not on a phase converter, is the voltage drop "on start up" causing a breaker to jump out if so which one? and is it worth replacing? which transformer supplies the control breaker? can I up the voltage on a tapping on the transformer?
Old 09-18-2010, 07:09 AM
gus gus is offline
I don't recall if the interact has it, but if it does, big transformer, change the jumper settings not rocket science. My R2C3 did exactly this when I first owned it.
"low end" HF Spindle or "high end" router for about $1000? biomed_eng DIY-CNC Router Table Machines 14 01-06-2012 12:15 AM
What encoders would you recommend for "Bridgeport Series II Interact 2" CNC conversio ichudov Bridgeport and Hardinge Mills 1 06-07-2010 04:53 PM
Weight of "Bridgeport Series II Interact 2" milling machine ichudov Bridgeport and Hardinge Mills 3 03-23-2010 04:21 PM
"Gross Postioning Error A" Doing M03 on Bridgeport Interact Series 1 Mk2 MeTri Bridgeport and Hardinge Mills 5 12-27-2009 11:37 PM
uncontroled start of spindle when "z" home. bcbackoader 5T/5M 0 10-16-2008 06:37 PM
