Old 06-13-2005, 12:18 PM
zcases's Avatar
zcases is on a distinguished road
V2XT feedback
Our V2XT recently quit ("machine check failed" thread) and we have a 2SQ service tech coming wednsday to troubleshoot it.
If its another bad board - I am thinking of retrofitting the control with maybe Mach2, and gecko drives.
Anyone have any thoughts on this? If we indeed blew another board theres at least a $1K bill, seems like we could retrofit for less than that. Are the motors resolver or encoder feedback......will geckos work for either?
Scott
Old 06-13-2005, 08:51 PM
Moderator
machintek is on a distinguished road
The machine uses encoders on the back of each motor.
If this is a BMDC machine, pull the BMDC out and clean the edge connector with a soft eraser. Then push it back into same slot or another ISA slot.
Check CMOS that it is set for hard drive correctly.
Go to DOS and do a Scan Disk and a DEFRAG if you have DOS 6.20.
Good luck!
George
feedback isolator for laser owhite Laser Engraving & Cutting Machines 9 04-14-2007 09:34 AM
Daewoo Lathe feedback Gunner Daewoo/Doosan 10 07-26-2005 03:08 PM
V2XT Boot Disk Needed. v488 Bridgeport and Hardinge Mills 34 04-29-2005 01:03 AM
V2XT z belt replace jrrhotrod Bridgeport and Hardinge Mills 5 03-13-2005 11:03 AM
Feedback on an Emco ET-420 CNC Lathe Gunner General Metal Working Machines 8 02-03-2004 03:22 PM
