Old 08-26-2010, 04:49 PM
Lesmark is on a distinguished road
Bridgeport VMC 800/22 Parameters
Have a 1997 vmc 800 with a dx32 control...looking for parameters..
Mark
Old 08-26-2010, 08:48 PM
Moderator
machintek is on a distinguished road
The parameter file is a function of the software version.
It is called the BMDCPRMS.SYS file.
And such items as orient, tool change height, backlash, pitch error comp, spindle speeds, spindle gain, spindle encoder are machine specific.
Usually it is easier to install the software and it creates a generic parameter file which then gets edited.
George
Old 09-07-2010, 12:15 PM
Bridgeport VMC 800 "Z"
Recently replaced Z axis thrust bearing...went to check Z travel looks good...ran a program and looped it about 30 times....checked Z and it grew .006 . Shut down and restarted and zero went back to zero...ran a loop and z grew again....????? any clues
Mark
Need Help!- bridgeport interact 1 lost parameters thomasmc Bridgeport and Hardinge Mills 9 03-29-2012 12:44 AM
Need Help!- Bridgeport Interact 720 parameters M.G.Machinist Bridgeport and Hardinge Mills 3 01-07-2010 06:04 PM
TNC2500-Bridgeport 412 Parameters paulmenday Bridgeport and Hardinge Mills 4 02-01-2008 02:22 AM
Plz help: Lost all the parameters on our Bridgeport Oviksnc Bridgeport and Hardinge Mills 20 09-29-2007 11:15 PM
Bridgeport Interact 412/Heidenhain TNC 250 initial parameters pedrow Bridgeport and Hardinge Mills 11 04-04-2007 12:09 AM
