| TarHeelTom This is one of the places you can get them http://www.internationalscrew.com/pa..._injectors.htm
__________________ Mactec54 |
| Best to replace them all and flush the lines out, also take the pump apart and clean the reservoir, the oil gets gummy after many years use. Al.
| Here is another. http://www.devcocorp.com/american/bijurmeters.htm The Bijur are about $20 and they have an aftermarket part for about $17. Darek |
| There is a filter element and screens at the bottum of the pump you should replace also. Darek |
| We have taken the pump completely apart and cleaned it. Working fine as a manual pump now. There was a ton of gunk in the bottom of the tank. We do plan to take off all the lines and flush them, but got to get oil past the tee first. Thanks Tom |
| Need Help!- re Spindle Lube and Lube Pump | robkuhi | Tree | 15 | 10-24-2011 12:49 PM |
| metering valves for one shot oilers? | thomasfreedy | Benchtop Machines | 0 | 03-31-2009 11:35 AM |
| cleaning lubrication system metering valves | integerspin | General Metal Working Machines | 2 | 03-05-2009 02:24 PM |
| Series 1 Z Axis Lube Metering Unit | kewl_cat | Bridgeport and Hardinge Mills | 0 | 01-30-2009 11:14 AM |
| Metering/Dosing pump | pds | Mechanical Calculations/Engineering Design | 28 | 12-03-2008 02:31 PM |
