Old 08-18-2010, 09:06 PM
MCFletch is on a distinguished road
Smile Series 1 Vert. Mill - dissassembly knee Elevating Shaft
hello everyone, need assistance in how to remove the dial holder from the shaft to replace the bearing. The Dial holder appears to be frozen to the shaft and will not budge while using a gear puller. I do not what to damage the bearing retainer ring or bearing retainer adjactent to dial holder. Any suggestions or tricks to trade!
Old 08-18-2010, 09:56 PM
Moderator
machintek is on a distinguished road
The dial holder is friction fit. Just pulls off. Some easier. Some harder. Could let some penetrating spray sit in it overnight.
George
Old 08-20-2010, 09:32 AM
mactec54 is on a distinguished road
MCFletch
If you want to take the dial holder off the shaft they just unscrew,Sometimes they have locktite on them, & may need a little heat to break the loctite You can also take the whole shaft out with both bearings on, to work on it as a unit.
Here is a photo of the dial holder, if your part is like this, it screws off,I have some used parts for these units if you mess anything up
Name:	Bridgeport Knee Dial Holder-1.jpg‎
ID:	113087   Click image for larger version
Name:	Bridgeport Knee Dial Holder-2.jpg‎
Mactec54
Bridgeport 9"x42" Series I, Variable Speed Knee Mill gnrms EBAY ADS 1 07-13-2010 12:23 AM
Basic diff between mils knee, vert ect bogger44 General Metal Working Machines 4 03-10-2010 10:48 AM
Need Help!- Looking to buy a Bridgeport Vert Mill Briang701 Want To Buy...Need help! 4 01-15-2010 06:00 PM
Just IN- CNC vert. mill and turning center looking for work OZZCAR Employment Opportunity 0 09-22-2008 03:09 PM
3D Machining on a 3 axis vert mill broderi General Metalwork Discussion 1 04-14-2007 11:35 AM
