Old 08-11-2010, 09:20 PM
rogerfries is on a distinguished road
Overdriving the spindle with a VFD on a 2J
Anyone running a VFD on a 2J head? How fast can you/do you you run it? Right now I have mine set to 75 htz and is seems to hum along nicely. How fast is safe for the motor? Where do you leave the belt speed set at?
Thanks!
Old 08-14-2010, 12:06 PM
HimyKabibble is on a distinguished road
Thanks!
My machine is not a Bridgeport, but a Chaiwanese clone. I routinely run for hours on end up to 90Hz/8200 RPM with no problems whatsoever. It's a two-speed motor. In low speed, I'll run up to 120Hz.
Regards,
Ray L.
Old 08-14-2010, 12:16 PM
Al_The_Man's Avatar
How do you manage that Ray?
A 2 pole motor at 90hz would be <5400 and <7200rpm at 120hz?
Unless that is the output rpm and you are geared up by belt etc.
If four pole motor it would be half that rpm.
Old 08-14-2010, 08:04 PM
polaraligned is on a distinguished road
The varidrives gear up.
How hot does your quill (bearings) get Ray.
I have run mine at 5500 and after 10 minutes it is quite
warm with no load on the bearings.
Old 08-15-2010, 05:08 PM
79TigerPilot is on a distinguished road
I run my BP at 120Hz about 5400 RPM on the spindle and it gets a little warm but not to the point I woud worry.
Ray:
The new job must be keeping you busy, not seen much from you lately.
Quill Drive is working great but progress on the rest of the mill has been slow.
Craig
Old 08-15-2010, 06:22 PM
Do you have the packed grease bearings?
I wonder if mine runs warmer because of the packed grease.
Old 08-16-2010, 10:30 PM
It's a step pulley machine. With the motor in high range (2-pole), high-speed pulley, 60Hz, the spindle turns 5440 RPM. At 90Hz, that's 8160 RPM.
Regards,
Ray L.
Old 08-16-2010, 10:32 PM
I've run mine at 8200 RPM for hours at a time. After 2-3 hours the spindle will be up to maybe 110-120F - not hot enough to be a problem.
Regards,
Ray L.
Old 08-16-2010, 10:33 PM
Ray:
Craig
Craig,
Haven't so much as turned the machine on since Feb, and don't anticipate being able to do so any time soon...
Regards,
Ray L.
Old 08-16-2010, 10:36 PM
My understanding is, for a high speed application, you want to only fill the spaces between the balls only about 20% with grease, not pack them. I have no idea how mine are setup - I've never touched them since I bought the machine about 3 years ago.
Regards,
Ray L.
  #11   Ban this user!
Old 08-17-2010, 06:29 AM
Thanks Ray.
1992 VF2 Alarm 123 spindle Spindle Drive Fault dafowfidy Haas Mills 15 05-14-2012 01:32 PM
spindle motor and spindle control dont work customcncparts Milltronics 0 10-01-2009 02:08 PM
Sweo spindle drive? new mill dead spindle Shizzlemah Fadal 13 12-18-2008 11:11 AM
Overdriving a stepper motor RChadwick Open Source Controller Boards 4 08-01-2008 01:56 PM
Lathe spindle bearings and spindle material mackeym Linear and Rotary Motion 1 08-11-2007 10:53 AM
