Old 08-07-2010, 08:52 AM
supahonkey is on a distinguished road
Bridgeport - Compress spring to remove motor?
I am trying to remove the motor from my Series I. Unfortunately the spring and the pad it seats against are rusted. The manual says "Using two screws "A", compress spring "C"". Screws "A" are the small socket head cap screws that retain the lower motor cover. The two holes in the pad for the spring are thru holes; there is no thread on them. The bolts don't seat against the spring when I stick them through. Any ideas?
Thanks,
Brenton
Old 08-08-2010, 03:27 PM
Nevermind. It appears as though the wrong (too short) bolts were retaining the cover. I got out a flash light and saw the casting with the two 10-24 tapped holes in it. I grabbed a set of 1.25" 10-24 bolts and they worked just fine.
Nema # Bridgeport CNC Motor???? endmill1 Stepper Motors and Drives 2 03-04-2009 10:15 PM
Need Help!- 110 vs 220, 1 hp motor on old Bridgeport JKENIK Bridgeport and Hardinge Mills 17 01-08-2009 03:58 PM
Bridgeport clock spring seiz0r Bridgeport and Hardinge Mills 4 11-03-2008 10:37 PM
Need Help!- Remove bridgeport spindle/quill? mc-motorsports Bridgeport and Hardinge Mills 8 10-17-2008 02:56 AM
How do you remove motor shaft key? walter General Metalwork Discussion 8 10-08-2007 02:42 PM
