Old 07-28-2010, 04:24 PM
ichudov is on a distinguished road
Someone says: Bridgeport interact cant make perfect holes,as timing belts STRETCH!
Someone I know said that he heard that "Bridgeport Interact mills cannot mill perfect holes because their timing belts stretch".
Just how true is this? How stiff are the timing belts and how much does their stretching affect accuracy of the mill?
i
Old 07-28-2010, 05:08 PM
gus gus is offline
gus is on a distinguished road
define perfect
I doubt belt stretch is the third most significant thing involved in accuracy
Old 07-28-2010, 06:07 PM
TOTALLYRC is on a distinguished road
Ballscrew backlash is several orders of magnitude a greater factor than belt stretch. A properly tensioned belt will have almost no stretch and millions of machines were and are built using belts.
My BTC-1 makes pretty round holes but since there is .003 backlash in the screws they are off at the compass points.
No offense Gus. LOL
Mike
Timing Belts kingpav Linear and Rotary Motion 1 09-28-2008 09:54 PM
Problem- Machining not perfect holes greasetattoo Benchtop Machines 11 05-19-2008 02:50 PM
Bridgeport Series II Interact 4 Z-Axis Timing Belt UKRobotics Bridgeport and Hardinge Mills 5 01-04-2008 04:47 PM
Timing belts, why not use? wwminc Linear and Rotary Motion 10 09-03-2005 10:03 PM
Timing Belts chas DIY-CNC Router Table Machines 1 01-19-2005 09:03 AM
