Old 06-01-2005, 08:48 AM
mmm2003 is on a distinguished road
No boot on EZ-Mill DX2 BPT
Hello:
It's me again.
Some may have seen my previous post, about our mill not booting. I was able to make that work, with some help "MachinsTek" and others. Thanks!!
Now our BPT won't boot, again. We are getting a checksum error.
After reading some more threads on this board, I suspect the battery is dead, since the date and time are off as well. I have the following questions, which I tried to research here, but found conflicting/confusing info.
We have a BPT EZ-MILL DX-2, serial number EZ-3309, 2-Axis control.
1.) How many batteries are they?
2.) Where are they located?
3.) How do I remove them?
Any help would be appreciated.
Thanks in advance.
Peter aka MMM2003
Old 06-01-2005, 09:16 AM
Exclamation
I just checked again.
I found one, rectangular, black 3/4 x 1.5" box on the motherboard. It reads the following:
Real-time clock
Lithium Battery
A2116A
Is that the CMOS battery? Are there others? I didn't find any other obvious ones.
How do I change it? It seems soldered in place.
Old 06-04-2005, 05:17 AM
UKRobotics is on a distinguished road
While I know very little about bridgeport machines, from my experience in computer hardware what you've described sounds very much like the CMOS battery to me. I have never come accross any system that uses more than one.
It should have a voltage written on it somwhere. Any lithium battery of the same voltage available from somewhere like maplin, farnell or RS should do the job fine.
If the black box only has two pins soldered into the board, its probably safe to assume that it is just a battery so there should be no problem if you disconnect all power from the machine, desolder it, and replace with a new one.
If it has more than two pins its possible that it is a combined battery and RTC chip in one. If that is the case finding a replacement may be more difficult, but not impossible.
Please bear in mind these are just a few ideas based on my knowledge of PC repairs, I cant gaurntee that my suggestions wont cause your bridgeport to spontaniously combust
Dom
http://www.ukrobotics.com/projects
Old 06-04-2005, 10:28 AM
Moderator
machintek is on a distinguished road
This is the CMOS battery. It is actually a device that usually plugs into a IC socket. Do a goole search for this device. I did this for the V2XT group on Yahoo. They called and found out that the manufacturer has changed names. It was DALLAS. They were sent some free samples by just calling.
George
how to mill angles? cowanrg General Metalwork Discussion 19 05-14-2007 09:35 AM
Boot disk for EZ-Track DX, batch file? mmm2003 Bridgeport and Hardinge Mills 8 01-31-2007 11:47 AM
Tree Mill conversion Questions Flyinfool General Metal Working Machines 7 05-27-2005 10:37 PM
Any options for an old mill? bjorn General CNC (Mill and Lathe) Control Software (NC) 1 03-04-2005 10:55 AM
Pictures of My Lathe & CNC MILL studysession General Metal Working Machines 14 01-04-2005 04:07 PM
