I have a retrofit Logitrol kit I bought from a man who originally bought it for this BOSS 5 mill that I also bought from him. The kit has NEMA 34 motors and the half inch diameter shafts are about half as long as the original 5/8 stepper motor shafts. I know there are negatives to NEMA 42 compared to NEMA 34 motors concerng torque and rpm's but I can not use the NEMA 34 steppers due to shaft issues. I have Gecko 201 drives ..... what would be my best choice for a new NEMA 42 stepper. I plan to sell the NEMA 34 motors can anyone help me out? ![]() ...I have a 1:1 drive pulley ratio on this machine. Last edited by CNCISME; 07-21-2010 at 06:50 PM. Reason: I'm not telling |
From what I can tell, the NEMA 42 motors that Bridgeport uses were most likely built to Bridgeport specs by Sigma and Superior Electric. They have a longer-than-standard output shaft and a nonstandard diameter. I have a Boss 3 and am also interested in replacement motors. My machine is running with the original steppers with Compumotor drivers and Mach3. If you have the original motors, use them to get going. It seems that normal NEMA 34 motors have a 1/2" shaft and NEMA 42 motors have 3/4" shafts. Both are still too short. The original steppers are a very old design and are not optimized for micro-stepping. I am looking for replacement motors so I can gain the advantages of micro-stepping. Smoothness at low feedrates and better resolution should improve surface finish (especially when interpolating). My plan is to use NEMA 34 motors with a ROUND 1/2" shaft (no flats) and make a 5/8" shaft extension.
__________________ "Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take away." Antoine de Saint-Exupery (1900 - 1944) |
Thanks HawkJET Check out my "Adapting NEMA 34 steppers to original pulleys" thread if you haven't already... unfortunately my motors had flat shafts but Mactec has a good solution for me. How will you lock the adapters to the shafts ? |
Since the pulley is about an inch from the face of the motor, I'll make the adapter 3/4" dia. between the pulley and motor face. I'll step it down to 5/8" for the pulley to fit. The 3/4" diameter will give me extra beef to allow for a decent 'squeeze' for a shrink fit. The adapter bore will be about .001 interference fit, and will be heated to expand it to slide onto the motor shaft. When it cools, it will be locked in place.
| 3 NEMA 34 Steppers on Ebay (No Reserve) | milhead | EBAY ADS | 0 | 02-01-2010 12:04 PM |
| Wanted: Broken Nema 23 and 34 steppers | groomden | Want To Buy...Need help! | 0 | 12-23-2008 11:52 AM |
| Need Help!- Replacing nema 42 steppers with servos | bseibenick | Servo Motors and Drives | 0 | 05-03-2008 10:47 PM |
| 570 oz/in nema 23 steppers | cut more | Stepper Motors and Drives | 2 | 10-01-2007 06:03 AM |
| Mounting holes for nema 23 and 34 steppers | andrew888 | Stepper Motors and Drives | 2 | 03-15-2007 10:18 PM |
