07-19-2010, 10:57 PM
Originally Posted by rolfinator2002 I know the factory quill fit is 0.0003-0.0005".
After stripping my head and cleaning the bore, my 0.0001" increment dialtest measurement , with dialtest located w/i 1/2" from the housing, with the quill fully retracted, and fully extended is the same, and approximately 0.0008" for both x and y axis. Tells me the bore is not measurably tapered. Lateral force on the quill in both cases was about 15 lbs.
Does Bridgeport advertise a service limit, or max recommended limit for this dimension?
The difference between a great mill and a so-so mill is tolerance.
Can I expect good cnc operation, or is this getting into "cheap" territory?
I have lots of machine experience, but this is my first mill rebuild.
Opinions highly valued. |
I'm not sure what you actually measured, here. If you can apply 15 Lbs radial force at the spindle in both directions and the indicator doesn't change, then the quill is a good fit in the bore. Is that what your .0008" reading is? Taper is not the issue, looseness is. Your .0008" could be deflection of the parts, not looseness in the fit. Depending on where you mounted the DTI from, this could easily be deflection of the head, ram, etc. Did you mount the DTI on the table? You should know that the head of a Bridgeport can be deflected .001" or so with relatively modest force applied to the spindle (I think maybe it takes 50 Lbs to do that). If you can mount the DTI onto the HEAD, you might get a smaller movement.
Jon |
