Old 07-10-2010, 06:56 PM
TarHeelTom is on a distinguished road
Question Wire size and type to steppers
Am rehabbing a Bp Series 1 CNC boss 5 machine.
Would like to replace the six wire cables from the controller to the steppers with new 4 wire cable. Anyone have a good idea what type cable and wire size is needed here, and a source?
Using gecko 203V's, 56 volt 8 amp power supply.
Thanks,
Tom
Tags
bridgeport, cable, steppers, wire size
What type wire for IDC connector? js412000 Pico Systems Motion Control Products 5 02-20-2010 08:05 PM
Via shape/size and wire size. Drools PCB milling 0 08-14-2009 09:47 AM
Wire EDM - Wire Type and Size greenchair General Metal Working Machines 0 06-17-2009 01:44 PM
power supply size? for multi wire (total 250 inches of wire) DanOSB CNC Wire Foam Cutter Machines 5 03-02-2009 04:34 PM
what size/type steel? 472viper General Metalwork Discussion 1 04-03-2008 11:34 PM
