How does one physically measure the backlash and linear compensation on a Bridgeport Series II Interact II Mill ? Need the machine to run as accurate as possible so need this info to set the parameters. ... Just read about using a dial gauge http://www.cnccookbook.com/CCBacklash1.htm to directly measure backlash, but what about the linear compensation ? Thanks, Joe |
| Does your control support linear compensation? For backlash, I put in a value of .005 inches, cut a circle with a spring cut, measure the circle and i can see the steps as the axis changes direction. This I subtract from the .005 inches and it should be pretty close. Anytime I see a backlash value exceeding .0035 inches, I know that axis has a problem. Also older machines may have the backlash different between the center of the table where the machine is typically used more vs the ends of the table. A ball screw regrind might be necessary. Pitch error compensation requires a step gauge or a laser. George
| Newbie- z0 measure | albert.B | Fanuc | 4 | 08-29-2008 07:14 AM |
| Backlash or motor tuning problem? How do I test for backlash? | Brian Queen | Mach Mill | 8 | 03-10-2008 03:35 PM |
| Servo idea - elimated backlash - zero backlash ! | synthetiklone | Linear and Rotary Motion | 6 | 12-06-2006 01:35 PM |
| Need measure | titoniks | Industrial Hobbies (Support forum) | 6 | 09-09-2006 01:27 PM |
| Measure Rpm | jhwatts | General Electronics Discussion | 13 | 09-18-2005 11:08 PM |
