Old 06-22-2010, 08:43 AM
joetx78239 is on a distinguished road
Lack of memory
I have a Bridgeport EZ TRAK.
I can only get it to load 1000 blocks of information.
any way to load larger programm
Joe
Old 06-22-2010, 06:22 PM
Moderator
machintek is on a distinguished road
The program size is limited by the memory of the BMDC board. When you save and load, the save goes to your hard drive and load goes to your BMDC.
If you have a 3 axis EZTRAK, it can DNC (drip feed) thus allowing you to run programs bigger than the memory of the BMDC. The 2 axis software cannot.
George
Old 06-23-2010, 11:31 AM
Gncc50 is on a distinguished road
DNC EZtrak
You should be able to run a program of a 1000 lines easily. You may have another issue. Usually you can run around five to six thousand lines before you reach the 256K limit.
Check out this thread from awhile back. I took some pictures of my control. Hope this will help you out.
http://www.cnczone.com/forums/showthread.php?t=80418
Pete
Old 06-25-2010, 03:29 PM
Cool THANKS
George and Pete
Thanks for the information.
I am using a mastercam post MPEZTRAK which puts out a pgm file
a MPEZTRKG which puts out a TXT file.
Both are setup to count the block numbers in 10 digit increment
N1000
N1010 and so on I need to change the post.
hitting that N9999 is a problem.
Old 06-26-2010, 09:57 PM
Line Numbering
I don't know if you were able to modify your post yet, but just in case there is a way you can do it right on your control. Go to the edit screen and hit number 2 for resequence. Enter 1 and 1 and it will renumber your program by ones.
Hope this helps you out.
Pete
Old 06-28-2010, 08:05 AM
Pete
Thanks ! I got the post fixed on the numbering.
Now I have to fix the post so it will drill.
It hangs up on the drill cycle.
Error 509 arc lack intersection dresda Milltronics 2 11-02-2009 04:23 PM
Newbie- Lack of Vacuum Donny Strange DIY-CNC Router Table Machines 2 07-15-2009 11:05 AM
The Lack Of The One Program To Do It All And Do It Right berin OpenSource Software 7 01-15-2007 12:15 AM
Complete Lack of Experience rcazwillis General Metalwork Discussion 6 12-04-2005 08:48 PM
PICStep and the lack of updates! Garfield2 PicStep Controllers 2 05-21-2005 05:00 AM
