Old 06-20-2010, 07:40 PM
dmschell is on a distinguished road
Bridgeport Boss 6
Ive recently acquired a Bridgeport boss6 series 1 cnc mill and was wondering if I could run the entire thing off of a VFD since I do not have access to 3 phase power? Is this possible or will it hurt something in the process?
Old 06-21-2010, 08:37 AM
keebler303 is on a distinguished road
You could either get a phase converter (different from a VFD) and be ready to go or you could run the axis drives from single phase and use a VFD for the spindle motor. It would take some rewiring to run the axis drives from single phase but it can be done. Each one uses one leg of the 3 phase power. You just need to connect all three to the single phase. I am not sure what all is involved with this but I have heard of people doing it.
Matt
Old 06-21-2010, 07:59 PM
polaraligned is on a distinguished road
Rotary is the easiest way.
It is a lot to invest only to find out that the control
is junk.
Bridgeport Boss 6 dmschell Bridgeport/Romi Lathes 5 08-16-2010 08:33 AM
bridgeport boss 8 AdamD Gecko Drives 2 11-17-2009 12:30 PM
Need Help!- bridgeport boss 4.0 ndc General CNC (Mill and Lathe) Control Software (NC) 0 10-11-2009 06:13 AM
bridgeport boss 4 jodybo Bridgeport and Hardinge Mills 0 02-25-2008 09:19 PM
Bridgeport Boss 5 Amperage jderou General Metalwork Discussion 3 05-12-2005 08:10 PM
