Old 05-24-2005, 11:11 AM
pcsimp is on a distinguished road
Machining small steps.
I noticed on my first project on the Bridgeport Series2 Boss9 that it would hesitate when it machined tool paths that were made up of short steps instead of machining in a smooth continous motion. Would turning off deeceleration smooth up the motion.
Alan
Old 05-24-2005, 02:32 PM
Moderator
machintek is on a distinguished road
Are you using cutter comp? This forces the control to look 5 steps ahead. It may help. I owned a BOSS 9 back in 1996 but cannot remember how I overcame the hesitation. It was not that bad for me. There is a G code that changes the feedrate automatically as the cutter goes around the inside or outside of a radius. It is used to keep a constant chipload on the cutter. You could try playing with that also.
If you are doing 3D milling with a program generated by a CAM system, then your steps are very small, the programs are long and the processing speed of a control designed in the early 80's may leave a lot to be desired.
George
Old 05-24-2005, 10:17 PM
The small steps are coming out of Visual Mill. I have no idea why it programmed steps into the tool path. It was a straight line only at an angle. The Visual Mill people did not see any problem. I think they are used to more modern controllers like you said.
I have been machining with a ShopBot for 3+ years. This is my first foray into the world of Gcode.
Alan
Old 05-24-2005, 11:36 PM
DAB_Design is on a distinguished road
If it is a straight line, you could just edit out all the lines except the starting point and the end point. Guess it would be a bit redundant to have to do that to every program though.
Quick and simple fix though.
Dustin B.
I hear and I forget.
I see and I remember.
I do and I understand.
White Papers; Highspeed milling with small tools HighSpeed Hard and High Speed Machining 2 11-12-2005 04:37 PM
Machining 2219-t4 aluminum scottwally General Metalwork Discussion 2 06-18-2005 10:53 PM
Help to pick small (not mini) CNC Lathe 5axis General Metal Working Machines 5 02-03-2004 05:35 PM
Lost Steps How does it Happen? High Seas General Electronics Discussion 1 01-30-2004 08:57 PM
