Old 06-16-2010, 12:56 PM
nesmitt is on a distinguished road
bridgeport r2ew
I recently got a bridgeport r2e3 and am trying to get it up and running. Upon startup, it displays error code 4000 and the fault lights in all three drives is illuminated. Any thoughts or advise would be appreciated.
Old 06-17-2010, 10:17 PM
Moderator
machintek is on a distinguished road
Enable the drives and have someone watch them. For a split second the lights will go out on the good drives. Assuming you isolated the bad axis, mark it and swap it with another drive. If the problem follows the drive, it may be the drive, otherwise it may be the motor or cables.
George
Old 06-18-2010, 05:57 AM
thanks for the information....I'll give it a try and go from there.
Old 07-15-2010, 02:19 PM
r2e3 bridgeport
finally back from vacation and trying to figure out my mill. Upon enabline axis drives error 4000 blinks on the display. The fault lights in all three drives show fault instantly. I have observed them very carefully and they appear to all light at the moment you enable the axis drives. Any thoughts or suggestions would be greatly appreciated.
Old 07-15-2010, 11:34 PM
Moderator
You may need to hook up the FIST monitor. Directions are in the maintenance manual.
George
Old 07-16-2010, 08:25 AM
Is this monitor a diagnostic device that is not part of the machine? If so, is there any suggestions on how to test without it?
thanks,
vince
Old 07-20-2010, 09:51 PM
Moderator
The R2E3 has a very limited display. For that reason, Bridgeport came up with the FIST monitor. I use a old compaq laptop running WIN95 and use PROCOMM in the chat mode. This allows me to access the boards and a event monitor that is a lot more specific. It is accessed through K3 on the FMDC board. Directions are in the maintenance manual.
George
Need Help!- bridgeport xr 760 imac Bridgeport and Hardinge Mills 4 04-22-2010 03:40 PM
Newbie- Bridgeport VMC 760 22 mak0 General CNC (Mill and Lathe) Control Software (NC) 12 11-10-2008 05:22 PM
Bridgeport Needs Air? JQ_Quint Bridgeport and Hardinge Mills 4 10-25-2008 03:46 AM
Bridgeport Value? smird Bridgeport and Hardinge Mills 20 06-07-2005 11:56 PM
Used Bridgeport - What to look for? smird Bridgeport and Hardinge Mills 11 04-17-2005 10:45 AM
