all right, I finally got all the bugs worked out of my v2xt's speed control and now I've moved on to programming. I used Haas machines at my old job and became pretty familiar with their language. I've read the programming manuals for the brideport and have found that alot of the g-codes are the same. what i don't like about the v2xt's is when you have a programming error it doesn't tell you what the error is. My biggest question is how do you start off a program for this machine? what do the first few lines need in them? I would appreciate any information anyone has about programming these things. thank you. |
This is some proven code I use to run some 1/4 midget engine linkage parts with? I've included sections of the code of an endmill running cutter comp, a peck drill cycle as well as the end of the program so you can see how I wrap it all up. The single quotations allow notes to be added that the control will ignore. This is code I run on a 1995 Bridgeport Torq Cut 22. If I recall correctly I created this in Mastercam and probalby cleaned it up a little by hand. I come from a world of Fanucs, Yasnacs, Okumas, Mazaks, and Haas so I understand the learning curve. DX-32 isn't bad once you get the hang of it other than the tool setting procedure. What a nightmare when compared to the simplicity of other machines. 'MBM001 OP A & B/CAN USE .500 DEBURR' '2 WORK SHIFTS USED/G55 & G58' 'THIS CODE HAS ENGRAVING' T2M6 '.500 SC E/M .5 LOC' G0G17G40G80G90G55 X2.75 Y-.825 Z7. S4000 M3 Z.5 G1Z-.47 F30. M8 X-2. G0Z1. N104 X2.75 Y-.45 N106 G0 Z.1 N108 G1 Z-.235 N112 G41 X2.75 Y-.45 N118 Y-.1785 N120 G1 X1.4347 Y-.1785 N122 G2 X1.4168 Y-.1769 I1.4347 J-.0785 N124 G1 X.9028 Y-.0836 N126 G3 X.8572 Y-.0795 I.8572 J-.3345 N128 G3 X.7205 Y-.1193 I.8572 J-.3345 N130 G1 X.2611 Y-.4111 N132 G2 X0. Y-.487 I0. J0. N134 G2 X-.3232 Y-.3643 I0. J0. N136 G3 X-.4925 Y-.3 I-.4925 J-.555 N138 G1 X-1.75 Y-.3 N140 G2 X-2.05 Y0. I-1.75 J0. N142 G2 X-1.75 Y.3 I-1.75 J0. N144 G1 X-.4925 Y.3 N146 G3 X-.3232 Y.3643 I-.4925 J.555 N148 G2 X0. Y.487 I0. J0. N150 G1 X.7424 Y.487 N152 G2 X.7966 Y.4817 I.7424 J.206 N154 G1 X1.5299 Y.3375 N156 X1.9 Y.3375 N158 G2 X2. Y.2375 I1.9 J.2375 N160 G1 X2. Y-.0785 N162 G2 X1.9 Y-.1785 I1.9 J-.0785 N164 G1 X1.6674 Y-.1785 N168 G1 G40 Y-.4785 G0Z1. M9 G0 Z7. M1 T22 M6 '.093 DRILL' G0G17G40G80G90 G55 X1.865 Y.18 Z7. S4000 M3 Z0 G1 Z-.27 F7. M8 G83 X1.865 Y.18 Z.23 Z.06 X1.69 X1.5 Y0 M9 G0 G80 Z7. M1 T2 M26 M22 Last edited by vettespeed; 03-19-2011 at 09:12 PM. Reason: Added machine info, etc. |
meanmachine85: What is your procedure for setting Tool Length Offsets? I would like to learn this control along with you. I'm struggling also. Take a look at this short sample program and let me know what you think. The program is a Center Drill, Drill, Tap operation. It worked for me but my TLO are not correct. Regards, Bob G90 M6 G0 X-6.5 Y5.0 T1 S1000 M3 G0 X3.75 Y0.0 Z.1 G81 X3.75 Y0.0 Z.42 F1.0 G90 M6 G0 Z-6.5 Y5.0 T2 S400 M3 G0 X3.75 Y0.0 Z.1 G81 X3.75 Y0.0 Z.85 F4.0 G90 M6 G0 X-6.5 Y5.0 T3 S150 M3 G0 X3.75 Y0.0 Z.1 G84 X3.75 Y0.0 Z1.0 F9 M22 |
| TC-22 DX32 Keyboard | tpmx57 | Bridgeport and Hardinge Mills | 0 | 03-25-2009 08:56 PM |
| Newbie- New to me 308 with DX32 | Ranchero50 | Bridgeport and Hardinge Mills | 8 | 04-11-2008 11:12 AM |
| BOBCAD CAM V20 AND DX32?? | TRANSATOOL | BobCad-Cam | 4 | 11-26-2007 07:27 PM |
| DX32 control | gridley51 | Bridgeport and Hardinge Mills | 5 | 03-23-2007 04:56 PM |
| dx32 dnc | Alan bailey | Bridgeport and Hardinge Mills | 9 | 11-06-2006 07:14 PM |
