Old 06-10-2010, 10:21 AM
drail is on a distinguished road
Eztrak SX - program starting issues
Had an issue where we lost our floppy drive and boot up files on an older SX model Bridgeport. Replaced the floppy drive and controller board and finally found a copy of the EZ-trak files. I do not have a boot disk as such, but seem to have all of the necessary files for the programs.
I can start the machine up with a dos 5.0 boot disk and then switch to the disk with my expanded program files. I understand the machine originally used the floppy to store the files and uses on-board ram to run the files (no hard drive). I can run some files on the disk... ez-utils, ezload, pfm and everything seems fine. The red lights on the bmdc board go off when I run these files. Whenever I try and run the eztrak.exe program, the screen lights up blank white, the floppy drive begins accessing the file(s) from diskette, and things seem to be working normally. However, after a minute or so, the floppy stops and nothing shows on the screen. If I remove the diskette from the floppy, it is now blank and must be reformatted and the programs copied to it once again. Am I not getting or using the on-board memory correctly? Is it trying to run the program from the floppy and running out of memory?
Any help is greatly appreciated.
starting program chucker Fanuc 2 11-10-2009 12:28 PM
starting in the middle of a program panaceabea Milltronics 11 05-19-2009 08:54 AM
starting from the middle of a program panaceabea Haas Mills 8 03-27-2009 06:31 PM
Problem- Starting program in fanuc 6m Bolle_Ma Fanuc 4 10-17-2008 03:11 AM
Starting in the middle of a program.Old control. lostkoss General CNC (Mill and Lathe) Control Software (NC) 3 10-07-2008 09:11 AM
