Old 05-19-2005, 08:07 PM
pcsimp is on a distinguished road
Drip feed Boss9
Can a Boss9 be drip fed through the remote port via pc. I have NCNET that I use for programs that will fit into the machine buffer. I now have a program that needs to be drip fed. NCNET will drip feed, will the Boss9 accept the feed through the remote port.
Alan
Old 05-19-2005, 09:26 PM
Moderator
machintek is on a distinguished road
The BOSS 9 was designed to DNC through port B using a piece of software from Bridgeport called EZLINK. It was fixed at 4800 baud.
If you give me your email address, I can send you a PDF scan of a tech bulletin on PC communication to a BOSS 8 and 9 machine. It also addresses DNC.
George
Old 05-20-2005, 01:53 PM
George,
Just in case you did not get my email. My email address is symson@southwind.net.. I would still like to see the file.
This whole talking to an old computer is frustrating. The bad old days of packets, baud rates, irq's.
I am close to making it work. I receive buffer overflow errors. It seems as though the dnc link will not turn on until after I have already started sending from the computer. That is opposite for when I send small programs without dnc.
The cadem people do not know much about Boss9. They have given some suggestions.
Alan
Old 05-20-2005, 11:59 PM
gm3211 is on a distinguished road
A buffer overflow is from data being sent to the device (CNC) without a response from the sending device, PC. If you are using your standard comm port, disable the FIFO and give it a try. If you still have a problem, use a line or character delay.
Old 05-21-2005, 06:58 AM
Chip,
Could you expand on that some. I am not sure what FIFO is.
My solution for the moment was to turn the one large file into several small ones.
Alan
Old 08-12-2006, 07:38 AM
motomitch1 is on a distinguished road
http://support.microsoft.com/kb/131016/EN-US/
Inexpensive DNC for Drip Feed Tazzer Machine Problems, Solutions , Wireless DNC, serial port 3 01-28-2008 05:27 AM
Need Bridgeport EZ-Track G-Codes to build post soweebee Bridgeport and Hardinge Mills 13 01-28-2006 01:10 AM
Just found out I won't be able to drip feed w/RS232 jderou Bridgeport and Hardinge Mills 7 05-29-2005 03:36 PM
Trying to drip feed a cnc boss6 bridgeport cncboss6 Bridgeport and Hardinge Mills 2 03-11-2005 06:28 PM
How do I drip feed a program to my Fadal f.100 Fadal 17 11-15-2004 04:58 AM
