Old 05-26-2010, 08:01 PM
meanmachine85 is on a distinguished road
wide open v2xt
hi, I recently purchased a 1993 bridgeport v2xt. Everytime I turn the spindle on it runs at max rpm. I can type in any speed and it runs wide open all the time. Is there an easy fix to this problem? thanks!
Old 05-26-2010, 08:37 PM
Moderator
machintek is on a distinguished road
Is the air attached to the machine?
Have you tried the jog +/- button to adjust the speed? The air motor or solenoid may be jammed of defective.
Have you tried programming a speed?
Do you have a operating manual?
I remember that the BOSS 8 could have the auto speed control turned on and off. Do not remember if the V2XT could do the same.
George
Old 05-26-2010, 10:14 PM
NEATman is on a distinguished road
Speed Pot could be bad?
Hi George & meanmachine85-
I have a 93 V2XT, but I have retrofitted it with Mach3.
However, what I recall from my retrofit, could the potentiometer that is located in place of the normal variable speed indicator wheel on the front of the head be bad? That would send a false resistance value to the controller, and it could be trying to increase the spindle speed.
Keith
NEATman
Basic research is what I'm doing when I don't know what I'm doing. Wernher von Braun
Old 05-26-2010, 11:10 PM
I was just thinking about this tonight in the house. I noticed that when i programmed an M3 the spindle turned counterclockwise. I'll need to switch the wires on my plug. could that have anything to do with it?
Old 05-27-2010, 08:39 AM
Moderator
No. The speed feedback is from the position of the potentiometer under the cover at the top front of the spindle drive belt housing plus a switch at the high low gear lever to sive the proper speed range display.
George
Old 05-27-2010, 04:52 PM
Okay, now my new problems of the day. the spindle still turns backwards and it still runs wide open. We switched the legs on the incoming power and it didn't change. when i try to program a speed, a message comes up that says "rpm not available in any gear". I have air hooked up, with 75psi on the machines regulator. the jog rpm knob doesn't seem to work even with the jog. How do I check out the air motor that you mentioned could possibly be jammed? It also doesn't help that I don't know my way around this machine very well, so I could be missing something really important. thanks.
wide face rack eloid Want To Buy...Need help! 2 01-26-2008 09:42 PM
3/4 wide rack eloid DIY-CNC Router Table Machines 0 01-06-2008 10:33 AM
How wide a Y-axis? rlrhett Rockcliff Machine 2 10-11-2007 05:07 PM
searching far and wide Gandalf Deckel, Maho, Aciera, Abene Mills 5 08-31-2007 09:35 AM
wide, deep cut question fatboy55 Mini Lathe 2 12-14-2006 08:48 PM
