Old 05-23-2010, 08:28 PM
l u k e's Avatar
l u k e is on a distinguished road
Is this a 3 axis BP
It's a 1979. The guy is asking $3500 and has never hooked it up. He does not know if it's 3 axis machine, which it looks like to me, but I dont know these old machines, is it a 3 axis?
Any idea what it may be worth? (I would probably just strip the control and go with a Mach.)
Old 05-23-2010, 08:42 PM
polaraligned is on a distinguished road
BOSS 4.
X, Y, and Z axis. The controller on it is garbage. I would replace everything including the stepper motors.
Yes, with a new controller like Mach 3 you could do 3 axis work.
It's honest value is well under $1000.
Old 05-23-2010, 09:57 PM
l u k e's Avatar
Thanks, that's pretty much what I thought too.
What are the chances of the iron being in good condition?
Old 05-24-2010, 05:20 AM
Pretty good. A lot depends on what materials they cut.
These machines had automatic oilers and were broken half the time.
Old 05-24-2010, 10:06 AM
l u k e's Avatar
Any advice for inspection, what should I look for? The mill is not under power and has sat for years.
Old 05-24-2010, 11:11 AM
keebler303 is on a distinguished road
You want to look at the ways and see what they look like. Take pictures and post them up. You can move all the axes by taking the belt covers off and turning the motors by hand. Move all the axes through their entire movement and look at the ways to make sure they are not heavily worn or scratched. Also want to check out the spindle and make sure it doesn't have excessive runout and turns free.
Even with a thorough checkover, you are really taking a risk without seeing it run. It may be hard to detect problems with the spindle bearings without being able to run it.
The price should be $2000 or less. There were recently several BOSS 6 machines on ebay very sinilar to this for around $1400.
Matt
Old 05-24-2010, 03:50 PM
Look for the obvious. Like Matt said, remove the covers and move the belts to check for free movement of the axis. Also, you can access how much backlash you have. A lot of the head parts, including all the vari-drive stuff is available.
I think well under $1000 is the right price, but it just depends upon how bad you want it.
Old 05-24-2010, 08:05 PM
Moderator
machintek is on a distinguished road
Remember that Boss 4 and 5 move in .001 inch steps. The Boss 6 moves in .0005 inch steps. Thus look at what you need and what BOSS level fits those needs.
Unless you have power to the machine, you will not know if the control is good and that can get costly.
George
Old 05-25-2010, 05:21 PM
BOSS 4 was a 1:1 pulley ratio and had a .001 resolution. BOSS 5 changed to a 2:1 ratio and had a resolution of .0005. There may have been some very early BOSS 5 machines that still had a 1:1 ratio, but everyone I have talked to with a 5 says the ratio is 2:1.
Anyway, the ratio is a moot point as the controller is a piece of crap. Even if it works, it is a piece of crap. JMHO. You need to go into this looking just to purchase the iron.
Old 05-25-2010, 07:01 PM
jacampb2 is on a distinguished road
About 2 years ago I bought a Series 2 Boss 6 machine made in 1982 for $500. The machine was in about the same shape as what you are looking at there. The S2 is quite a bit more rigid than the S1. I wouldn't swear to it from the little bit of a picture you give us, but that machine looks like a S1, there is no way I'd pay the kind of money he's asking. You'll have another ~1-2K into new control and drives depending on how good you are at DIY.
As mentioned above, the good thing about these machines is that their factory controls sucked, and even when they were in their prime they did not run reliably and so sometimes saw very little use. My Machine was in tip top shape except for the quill bore, the oiler quite working somewhere along the line and the quill bound up. I got it freed and cleaned up the bore and now it works very well. I think it is one of the best investments I have put into my shop!
Later,
Jason
1982 Bridgeport Series 2 CNC
1967 Clausing/Colechester 15x60 Round head Lathe
  #11   Ban this user!
Old 05-25-2010, 07:06 PM
Jason,
I got a Series 2 for $500 in super condition just a few years ago. It is the best knee iron that BP ever made. I have a series 1 also and it is no match for the S2.
  #12   Ban this user!
Old 05-26-2010, 01:56 AM
TarHeelTom is on a distinguished road
Originally Posted by polaraligned View Post
BOSS 4.
Polar,
I'm currently converting a Series 1 BOSS 5 to EMC2.
What would you use to replace these stepper motors?
Tom
Grinding and unexpected axis movement if rapiding 2 axis DarkSabre Taig Mills & Lathes 4 03-25-2010 11:37 PM
the Difference of 2-Axis and 3-Axis of Vertical Mill Machine begacon Knee Vertical Mills 6 07-30-2009 06:31 AM
New Machine Build- post for 2 axis ez trak versus 3 axis ez vision tooolman G-Code Programing 0 11-28-2008 03:33 PM
Compare Catia and MCX2 for multi axis lathe/4 axis mill bob1112 General CAM Discussion 0 10-10-2008 07:15 PM
New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter the__extreme CNC Wood Router Project Log 3 02-26-2007 02:58 PM
