Old 05-18-2010, 09:58 AM
espinja is on a distinguished road
BPT V2XT not booting
Hello,
I'm trying to get this machine to work.
The Harddrive is not working anymore CONNER CP30064H Harddrive (booting from it).
This machine has FMDC boards.
So we need to replace the drive:
Does any drive would work?
Does it need to be formated in certain way?
What software should we look for?
How do we load the software to the drive correctly?
Any help would be appreciated.......THANKS
PS: already check in the yahoo V2XT group but got confused
Old 05-18-2010, 10:11 AM
Al_The_Man's Avatar
If you want to clone the HD and it is not working at present, I have had some success by placing the HD in the freezer to get it working, and then use Acronis clone S/W to clone it, the Conner is a 61mB IDE drive, you will be hard pressed to find the same size drive.
It depends on whether the present bios will recognize a Gb drive.
Old 05-18-2010, 01:54 PM
will give a try in the freezer, see if it spins again....thanks
Old 05-18-2010, 07:05 PM
Moderator
machintek is on a distinguished road
ANY size hard drive will work but due to BIOS and DOS limitations, you need to Fdisk it to 503 MB. Make a DOS partition and make it active. The CMOS need to set accordingly. 1024 cylinders 16 heads, 63 sectors.
George
Old 05-18-2010, 08:03 PM
Ok, this means i need to partition the harddrive to 500mb with a win98 floppy disk.
on the other hand is this the right software V2XTSX4[1].41_3.41_6.20.exe (downloaded from the yahoo group)
...thanks
Old 05-19-2010, 09:00 AM
Moderator
I made a DOS boot disk and use that, followed by loading DOS followed by loading the machine software.
The software you mentioned above is per definition for a SX machine which has the FMDC and is written for DOS 6.20.
George
Old 05-25-2010, 08:20 PM
ok, finally got this to boot on ms-dos 5.0 with ms-dos shell.
next is to install software.
so try to install bossxt2.5,2.01 , but now it wont boot it shows incorrect DOS version at start up.
what's the correct program i need to install? I know the board is a XT-339.
Old 05-27-2010, 07:49 AM
Did more reading on the forum, found a few more pointers and the machine is back and running.
today will try a program see how it goes
5020L Not booting JasonMiller Okuma 8 05-13-2010 12:11 AM
Need Help!- MAZATROL FUSION 640 ...not booting... dinudesign Mazak, Mitsubishi, Mazatrol 9 11-18-2009 03:12 PM
Booting Up BDI 4.51 BMG LinuxCNC (formerly EMC2) 5 04-09-2007 05:45 AM
v2xt not booting kent Machine Problems, Solutions , Wireless DNC, serial port 2 09-04-2006 03:33 PM
V2XT Not Booting Up Idealchip Bridgeport and Hardinge Mills 15 10-22-2005 09:19 PM
