| Please help, the company i work for got a 412x tnc 2500 bridgeport . no manuals where sent with it. Went to Heienhan.com and downloaded the manual, but i cant get the machine to home it's axis's or get the door open. any help iwould be grateful thanks Tim |
| Does the control come on? Is power into machine correct? Is the 24VDC there? George
| If the control comes up but the drives do not turn on, maybe the emergency stop button is pushed in. This machine may have 2 24VDC power supplies. One powers the control. One powers the relays and switches, etc. Maybe if you do have 2 of these power supplies, one has no output. I do not know when I will get to the office to look for a schematic. George
| >>>>> no **** no **** dude. cycle start do you really think that will work??? damn i never thouht of that. will that really work? wow thanks for the info Forward Message >>>> If you think you are smart act that way If you need help ask the appropriate questions. You still have given absolutely no information to get any help here Even the non english speakers usually do better |
Gus ,I apologize for being a smart@##. .I followed what the manual said to do. power on Display says" Memory Test" The it says Power interrupted. I press CE Then 'I' Like the manual say's Then the display say's Pass Over Reference Point. When I did what you said CE c \start 3 times The display says Gross Positioning Error Z C |
Power up machine. [Memory Test]shows on display. [Power Interrupted]shows on display. I press[CE] [Relay Ext. Voltage Missing]doesnt show on display(it should?) I press [I] like manual say's. [Pass over reference point] shows on display. Gus said to press [CE] then c/start 3 times. When I do this[Gross Position Error z c ] appears on display. I will check on(2)24vdc power supplys Friday. If I am not giving enough info please let me know. I am new to this . Thanks again. Tim |
| DO the drives power up when you hit power enable? I am not that familiar with that machine, some of them do not know that they have not been 'enabled' so will spit out the gross pos error. end of the day, you do not have 24v you need to figure out why. You need to locate a bridgeport manual, sometimes ebay. |
#10
| Need Help!- Parameter needed for Bridgeport Int. 412X. TNC 2500 control | Eric Tay | Bridgeport and Hardinge Mills | 7 | 03-20-2012 05:17 PM |
| Bridgeport Interact - Heidenhain TNC 2500 | nycooh | General CNC (Mill and Lathe) Control Software (NC) | 3 | 06-08-2011 03:01 PM |
| Need Help!- Bridgeport Interact with TNC 2500 | bk1955 | Bridgeport and Hardinge Mills | 6 | 08-04-2008 06:18 PM |
| Need help. Parameter for Bridgeport Int. 412X. Control TNC 2500 | Eric Tay | Bridgeport and Hardinge Mills | 0 | 06-25-2008 09:29 PM |
| Bridgeport Interact 1 - Heidenhain 2500 | nycooh | CNCzone Club House | 0 | 06-25-2007 03:56 AM |
